Old 06-28-2016, 06:05 AM   #1
carguy83
carguy83's Avatar
Drives: 2009 Pontiac SV6, 2016 Camaro 2LTRS
HVAC no display on 8" screen
This morning as I adjusted my climate control hvac settings, the only thing displayed on my 8" screen was a large grey bar with the small letters reading "ac on" or "ac off" (depending on what I set). Normally it shows a picture of the corresponding button, blend/defogger etc etc. Anyone else have this issue or know the fix? I'm at 1600kms
carguy83 is offline   Reply With Quote
Old 06-28-2016, 02:35 PM   #2
carguy83
carguy83's Avatar
Update: car sat at work parking lot for 8 hours. I came out and started it and hvac modes are once again acting normal, by flashing current setting on the screen. Unsure of why this occurred today but as of right now it's all good
Old 06-28-2016, 07:15 PM   #3
StormBlaze
Drives: Hyundai Tiburon (Soon to be Camaro)
My car does this randomly as well, haven't bothered to go to the dealer about it as it usually sorts itself out on a restart later on in the day.
StormBlaze is offline   Reply With Quote
Old 08-22-2016, 05:37 PM   #4
DrRedD
Drives: Camaro 2016 2L Turbo
i get this too - seems to happen if i use the remote start - found this: http://gm.oemdtc.com/5176/intermitte...-dis#more-5176
Taking it into dealership to get all the software refreshed/updated on Saturday.....
DrRedD is offline   Reply With Quote
Old 08-22-2016, 06:22 PM   #5
JaxChris
Random issue in the display interface between the HVAC control module and the MyLink. If it bothers you (e.g. you're on a long drive), pull over real quick and restart the car to clear the problem.
Old 03-26-2018, 01:25 PM   #6
Slayer_TauNu
Slayer_TauNu's Avatar
Drives: 2017 RS
I get this issue pretty frequently on my 2017. Appears to only happen when I use the remote starter. Will have the dealership check the software when I get my 1st oil change. But this TSB says there is no solution yet: https://static.nhtsa.gov/odi/tsbs/20...99144-2280.pdf
2017 2LT RS V6
2001 Firehawk TA
1988 GTA
1987 C4
Slayer_TauNu is offline   Reply With Quote
Old 03-30-2018, 12:33 PM   #7
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
In most cases, this happens with A8 cars when remote starting. I have found that it seems to be a systems startup up timing/sequence issue. By unlocking the doors using my key fob first, then locking the doors, and THEN remote starting it, I’ve eliminated the problem every time. I never have the problem with the HVAC controls or with any drive mode settings disappearing. And now I remote start with confidence every time.
Give it a try!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 03-30-2018, 02:42 PM   #8
soldes
Drives: car
I've been following that advice for a few weeks now and the man is right!
Normal remote start : grey bar 90% of the time, with unlock lock remote start 100% hvac control display
soldes is offline   Reply With Quote
Old 07-14-2018, 06:35 AM   #9
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Since I encountered the same issue with my 2017 SS 1LE, I searched and found this thread.
I do not use / have remote start.
To me it happens occasionally, however, the workaround I found is to start the engine only after first pressing the Start button for ~ 10 seconds (going into active ACC mode) without engine actually starting (by not pressing the Clutch pedal...in Autos this would be not pressing the Brake pedal).
Only then, I press Clutch and Start button to start the engine as usual.
I do not think that the community should tolerate glitches like this and resort to workarounds (having to unlock/ re-lock doors before starting; go into ACC mode first).
Does anyone know if GM already has a permanent fix to this issue?
Firmware update of the HMI / HVAC-CM/ B-CM?
TSB ?
Old 07-15-2018, 06:11 PM   #10
PnCRedJwl2SS
Howdy! Pete here...
TSB ?
Even though you drive the M8, I'm curious if just unlocking with the key fob, then locking again with the fob, then unlocking with the fob will do the trick for you. If it does, at least you can avoid waiting the 10 seconds before every start...I'm thinking this electrical activity will "wake up" the car systems so they will start up in the correct sequence.
Try it and let us know!
PnCRedJwl2SS
Ordered from GM
Old 07-17-2018, 05:24 PM   #11
Eldi Z
Yep. Let me try this sequence and check for consistency in terms of what the screen shown when operating the AC.
I shall report back my findings after a couple of weeks of testing this.
Old 08-06-2018, 10:55 AM   #12
Eldi Z
Seems like this sequence of locking-unlocking actually works, however, it is annoying that I must rely on such measure for it to work properly.
Last night I forgot to do it and had the disappearing screens of HVAC and Driver Modes in the settings
Has anyone so far actually had the dealer update the FW to make it work as it should?
