Old 06-27-2016, 09:40 PM   #1
ender2664
Drives: 2016 2SS
0-60 videos
So my excesses for the bad times first
I came out to my car this morning and the passenger side rear tire was at 2psi so these runs are on cold tires at 42psi. Didn't want to warm them up and risk a blow out but I've been meaning to take videos for a while.
So 2 runs on cold over inflated tires 116 degrees out.
https://youtu.be/aVyFCweimsw
https://youtu.be/0Mt58Ty3REQ
You can see and hear that no spin is necessary, you just want the car to be able to get all its power to the ground as quickly as possible.
When I get my new tires I'll try to make a 3.6 video with a better view of the tachometer.
Also I'll use a video editor to make the videos shorter and remember to turn down the music.
ender2664 is offline   Reply With Quote
Old 06-27-2016, 09:52 PM   #2
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Appreciate the posts! Haven't tried timing mine yet, going to have to do so sometime soon.
Dude, dust of that column!
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 06-27-2016, 10:27 PM   #3
tbis
tbis's Avatar
Drives: 2016 1SS Summit White
What did u launch at 2500rpm?
[SIZE="100"]
tbis is offline   Reply With Quote
Old 06-27-2016, 11:01 PM   #4
ender2664
Drives: 2016 2SS
Closer to 2 than 2.5
Old 06-28-2016, 12:15 AM   #5
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Nice man, thanks for the videos! Great shifting, would love to see you take it to a 1/4 mile track and see how you do.
Richard0nee is offline   Reply With Quote
Old 06-28-2016, 12:26 AM   #6
ender2664
Drives: 2016 2SS
Thank you very much
The only track close to me is a 1/8th
I went there and made 2 runs but the track is so bad I left. When I shifted into second there was so much wheel spin I almost flew into the wall. Didn't finish either run so I'm not even sure on my 1/8th time.
I did just get a obd2 reader and plan on checking out my 1/8th with that once I get my new tire on.
Old 06-28-2016, 08:38 AM   #7
RazorbackSS
RazorbackSS's Avatar
Drives: 2016 Camaro 1SS, Black, 6MT
This is the first thing I noticed. To each his own, but I keep a microfiber cloth in the car and dust it nearly each day..
RazorbackSS is offline   Reply With Quote
Old 06-28-2016, 11:09 AM   #8
gfxv2388
Drives: 2016 Camaro 1SS Hyper metallic Blue
Dumb question here but how does the timer come on? Does this automatically happen in Launch mode? Under my accessories feature I do not see a timer. Thanks.
gfxv2388 is offline   Reply With Quote
Old 06-28-2016, 11:59 AM   #9
Lemosine
Lemosine's Avatar
Drives: 2016 M6 Hyper Blue 2SS
its under the performance category. that is where all the timers are.
Lemosine is offline   Reply With Quote
Old 06-28-2016, 05:18 PM   #10
GM Lifer
GM Lifer's Avatar
Drives: 2016 Camaro SS in Red Hot
Very nice. Makes me want to practice! I've done my best with a 2,000 RPM launch, as well. Although I do kinda feel sorry for the motor--running it close to redline when it's over 110 degrees out. Same problem here in Phoenix.
GM Lifer is offline   Reply With Quote
Old 06-28-2016, 06:22 PM   #11
E-Ray
Drives: 2016 Camaro 2SS, Nightfall Grey
Looks like you had some wheel spin the 2nd run. Thanks for the vids.
E-Ray is offline   Reply With Quote
Old 06-29-2016, 12:51 AM   #12
irmb
Drives: Camaro SS
Dayum. Good job.
It's not too often you find a manufacturer under reporting their product - but you and others are hitting 3.9 when they claim 4.3 for this car. That rules.
irmb is offline   Reply With Quote
Old 06-29-2016, 07:42 AM   #13
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
Yeah both of them spun into 60 mph quite a bit. Thats the problem with these timers. Every time I shift quickly from 1-2 it will spin the tires, no matter the condition, and it trips the timer. Someone needs to try a GPS timer instead.
Lucely Engineered is offline   Reply With Quote
Old 06-29-2016, 08:58 AM   #14
ender2664
Drives: 2016 2SS
Speed shot up, timer did not stop. Had the timer stopped I would not had needed to continue in second gear.
Significant wheel spin? Are you watching with the sound on? You can hear a small chirp.
If you are shifting the camaro quickly you get no more than a chirp.
