For those that keep complaining of your NPP rattle woes, and letting everyone know that NPP isn't worth it because of the rattles, there is NOW a fix for this concern.
Attached is a pdf of the page from service information.
reserved for future update.
Bump in the night
Drives: '84 Monte Carlo SS, '15 Optima Join Date: Oct 2015
We've heard about this "fix". It doesn't address the problem from a engineering/manufacturing viewpoint before it goes on the car.
It seems about the same as slapping some bondo in a quarter panel and calling it repaired. It may work for now but seems like a design problem has hasn't been properly corrected.
SABIO
I'd rather have a new exhaust. They want to glue my broken exhaust?
![]() Drives: 2017 2SS, HyperBlue, NPP, M6 Join Date: Feb 2013
Thanks for posting. Still not sure why this hasn't been addressed through engineering/ redesign of said product. Like someone said seems like a "band aid"..and we all know those eventually fall off!
2017 2SS Hyper Blue, Black hash marks, Black front splitter, SEMA Lower Grille, Kalahari, M6, Black Chrome 5-Split Spoke, Red Calipers, GlowTie (black), Sunroof, NPP, NAV.
4/29/16-1100 | 5/28/16-3300 | 6/29/16-5000 5/3/16-2000 | 5/31/16-3400 | 7/8/16 -6000 5/4/16-3000 | 6/14/16-4200 5/9/16-TPW 6/6 | 6/15/16-4B00 5/25/16-3100 |6/16/16-4300 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
I am not liking this fix one bit. We risk of messing up the valves even more if the tech accidentally gets epoxy in the wrong places. All this TSB did is tell us where the source of the rattle is coming from but the proposed fix is nuts. "Use a q-tip taped to a screwdriver..." Cmon. So, are all the new NPP exhausts coming off the line now having robots apply epoxy to a pin on the NPP valve? If not, then I want the newly design version of the NPP valve that has the proper size and clearance, etc. so it doesn't rattle.
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#7 |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2016
This is why they normally don't want you to see the repair procedure. 90% of the people who have this issue either don't notice it, or when they take it to the dealer all they know is that it is fixed. I'm sure the future valves will be fixed, but it is much cheaper / easier to have a dealer do this than replace thousands of valves.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: camaro Join Date: May 2013
This really is bullshit. Cmon GM! Wtf?
Hyperblue/JetBlack |
#9 |
![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
Crap, I've JB welded things before and it's been stronger after. If it works, it works. Some of you guys are never happy. The only change that will happen on the line making this product is adding more glue when its being put together.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
thank you for posting.
interesting the bulletin claims you can select different exhaust modes without the car running. My car doesn't do this. I wonder if a software update was released. I'll just be happy if it works. |
#11 |
![]() Drives: Camaro 1SS Join Date: Apr 2016
I found out the other day that you can select different exhaust modes with the car off. All you have to do is hold the engine start button for about 5-10 seconds and then your car will power on. You will now be able to adjust the exhaust in the settings. My NPP exhaust rattles too, so I just leave it in track or sport mode for now.
#12 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Thanks for posting, but come on GM; this really is not a fix but a temporary Band-Aid.
#13 |
other than crushing the metal on the ceramic pin, idk what they can do. you cant weld it.
i think this will fall under the powertrain warranty, so we have plenty of time to see if this will hold up |
#14 |
Sorry for trying to help everyone out, didn't know you would be such Nannies about it still. Guess i'll keep my mouth shut on all the other common problems when a repair comes out, because it will still not be good enough.
