Old 06-15-2016, 10:28 PM   #1
chris227
chris227's Avatar
Rear view mirror help
Does anyone have a clue on how to remove the rearview mirror?
I am getting a new one from my dealer for warranty but they have no clue how to remove it. I just want to avoid having to leave my car at the dealer for possibly a couple days over something so minor. Any help would be appreciated. Thanks
Old 06-15-2016, 10:31 PM   #2
BadBillyJack
Drives: 2016 2SS Camaro
what... just grab and twist the base. It's exactly like a c7 corvette if you can find the procedure for that with google-fu
2016 2SS Nightfall, A8, NPP, MRC, Jet Black leather.
Originally Posted by 20171LE View Post
The fact remains, the Camaro designers have another fail in not transferring the clothes hanger from the ATS to the Camaro.
I, and every other Camaro owner that hangs clothes in their cars, need a solution.
BadBillyJack is offline   Reply With Quote
Old 06-15-2016, 10:33 PM   #3
BadBillyJack
https://gsi.ext.gm.com/image_en_us/g...77/4177521.gif
Inside Rearview Mirror Cover
Procedure
Using appropriate tool, release the bottom cover from the mirror.
Procedure
 1. Adjust the mirror to the full upward position.
 2. Place a flat-bladed tool through both lower holes on the mirror.
 3. Using the flat-bladed tool, rotate the mirror 90 degrees to remove the mirror.
 4. Disconnect the electrical connector.
 5. Using the flat-bladed tool, install the mirror by rotating the mirror until an audible click is heard. An audible click is heard when the mirror is fully seated.
Note:
•DO NOT grab the mirror to remove or to install, you will damage the mirror.
•Ensure screwdriver is through both lower holes of the mirror or you will damage the mirror.
•More force is required to remove the mirror than to install the mirror.
Old 06-15-2016, 10:43 PM   #4
chris227
chris227's Avatar
Thank you. Thats just what I needed.
Old 06-15-2016, 10:49 PM   #5
BadBillyJack
Yeah dude, I help when I can.
Old 04-24-2017, 01:15 PM   #6
d00mz
Drives: 2020 Camaro ZL1 Convertible
Thanks again for this thread! I was at a loss as to how to remove the mirror in my new 2017 vert.
-d00mz
2020 ZL1 Convertible in Shock
-Bone stock (for now)
2017 ZL1 Convertible in Hyper Metallic Blue (sold)
-stock
2014 ZL1 Convertible in Red Hot (sold)
-Roto Fab Cold Air Intake with larger HX Rez
-2.5inch upper pulley, solid isolator
-Ported Blower Snout
-ARH 2 inch headers and longflow off-road pipes
-1000cc fuel injectors
-NGK TR71X plugs
-Catch Can
-Dyno tuned to 600RWHP
-All work done by Advanced Modern Performance
d00mz is offline   Reply With Quote
Old 04-24-2017, 09:59 PM   #7
Black_FiFTY
Custom Black FiFTY
Black_FiFTY's Avatar
Drives: 2017 Black SS
That's hilarious that the dealer doesn't know how to remove it
Wanted a F1FTY edition but decided to make my own
Black_FiFTY is offline   Reply With Quote
Old 04-25-2017, 08:31 AM   #8
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Not suprised on the dealer not knowing how to do it When they put my new headliner in they had no clue how to get it out of the car or put the new one in without bending creasing it.. they had to call GM technicians at corporate.. turns out the windshield has to be removed.
Dustya is offline   Reply With Quote
