![]() Drives: 2016 Procharged camaro ss Join Date: Jun 2016
FI track times?
Has anyone ran a 16ss with FI at a track? What 1/4 numbers and MPH?
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
Go to the dragstrip thread to see the 1/4 fast list. 2 guys running FI on there.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
There is actually only one forced induction car on the 2016 1/4 mile fast list. The fastest is a nitrous car, not really forced induction. Toohighpsi ran a 10.81 @128 mph using the Heartbeat PD blower and drag radials. I went to my local track hoping to put up some numbers that might challenge this and found that my local track has removed all sensors beyond the 1/8 mile. I did make 4 1/8 mile passes all very similar times. 1.80 60 feet (no spin at all on a tall M&H 325 drag radial) 7.7 @ 97 in the 1/8. My car is twin turbos and the turbos take a little time to make boost with a completely stock automatic transmission. He had significantly better 60 foot times and better 1/8 mile times than I could muster. I wish I had a close track with 1/4 mile sensors because my car comes on hard after the turbos are spooled. I think if I was running a shorter tire on this 2016 it would have helped the times also.
Your procharger should be good for about a 10.9 to 11.1 depending on tire and traction.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
That is what I was curious about. I dyno'd 623 rwhp with just Procharger on their dyno. Then added headers with full exhaust, snow meth kit and a smaller pulley on the Procharger and 315 radials. Last night at Topeka I ran best 11.4 @ 124 mph. Granted the conditions where not optimal but was till hoping to be better than 11.4.
#5 | |
Speed Freak
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Launch is critical to having a good ET, I'm currently on the Hot Rod Power Tour and we ran at Royal Purple Dragway in Baytown, TX on Sunday - I was only able to run 11.2s there. Best 60' at Royal Purple was 1.80 launching at idle, where I had previously ran 1.55 launching at 1500-1800 RPM. Not sure if it was because of all the street tire cars running through the water that afternoon, or if it was because the new tires that we had put on the car. When I ran the 10.8's I was using a set of 305 nittos that were a few years old, I have switched to a new set of 275 ET street Rs which I thought would be better... Hopefully we will run the car again on Saturday at the Roadkill Nights on Kansas City, since I see you're in that area Sandkillman maybe we'll see you there!
With a centrifugal you're not going to have a bunch of extra toque at the line to get the car moving, in this case I would normally run a higher stall converter in the transmission to offset this low speed deficiency. With the PD, the torque is available, but only useful if it is put to the ground. We'll see how this works on Saturday, if I can't hook there then I will be going back to the Nittos on the car! |
#7 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
In on this conv.....
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
#8 | |
. You'll need HP tuners - then you can remove a bunch of ignition timing when you are at the tree to dump heat in the exhaust and get the turbos spooling a bit earlier. Turbos will never have the response of a PD, but that might help you a bit to drop your 60'. Just don't get too carried away, you can make more heat than most pre-turbo exhaust systems can handle...don't ask how I know.Mike |
#9 | |
Speed Freak
Thanks for the info, I'm really not looking to drag race the '16 since it is my daily driver. I just took it out on a fun drags night hoping to get a competitive time. My car was dead hooked on the M&H drag radials but pretty lazy out of the hole. I don't know what is available for the 8 speed in an aftermarket torque converter with more stall but suspect if someone was serious that would be the way to go. Good luck on the Power Tour. Jess
