| View Poll Results: More rwhp | |||
| ZL1 |
40 | 59.70% |
| Z06 |
27 | 40.30% |
| Voters: 67. You may not vote on this poll | |||
Thread Tools |
![]() Drives: 20 2SS 1LE Join Date: Feb 2015
Which will put more power to the ground?
Curious what you guys think.
![]() Drives: 2013 Audi TTRS, 2013 Ford Edge Join Date: May 2016
Manual for manual, auto for auto, I think ZL1 because it will likely have been engineered with better cooling (don't want to repeat the Z06 issues).
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
The ZL1 has a bigger front intake area (grill) so it will breath better.
I used to be Dragoneye...
SS has been reported to put power down better than the Stingray. Not by much...but at least a little...I imagine the same will be true of the ZL1.
if its GM advertising, id say the Z06. Real world? probably will depend on the day and the dyno.
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
Please clarify power to the ground. Dyno? 1/4 time? Cornering?
#7 |
![]() ![]() ![]() ![]() Drives: 66 Chevelle SS Join Date: Mar 2013
How would one know without having the spec's?
#8 | ||
Moderator.ca
The OP wants to know what we think will happen ... ie, our guesses and opinions based on past knowledge and experience. Read the post, not just the title
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#9 |
![]() ![]() Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Cooling will have zero impact on dyno numbers.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
#10 |
![]() ![]() ![]() ![]() Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
I see this as being over 650hp.
Don't forget, the supercharger is physically bigger than the z06. Is it because it has a larger plenum? Or is it larger than 1.7L? Most likely just the plenum, but they would get a lot of good press if they went bigger. Corvette does not keep the Camaro down, plus there may be a zr1 coming. |
#11 |
I agree, however the question is not clear. Does he want a true measurement or the actual performance on a track? I see his poll asking for rwhp, but it still begs the question of "putting power down" in a practical sense.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
I think what the OP is asking is which car will put useful power to the ground? Say on a drag strip or at the track.
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
#13 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
ZL1 will put down more to the wheels stock for stock than the zo6 on the dyno. 2 things will make that happen... Tune on the ZL1 will be a bit more aggressive from the factory because GM knows how to tune them better and also IF the ZL1 will have Tri-y headers. Those 2 things make quite a bit the difference. But keep in mind... Just because it will put down more power than the C7 Zo6, does mean it will be faster. Weight, aero etc, even if the other variables like weather is perfect. I am willing to bet that ZL1 stock tires are 100 times better than the NON-ZO7 tires are when it comes to putting down power though.
#14 |
I really meant dyno numbers for the LT4, since the SS put down more than the C7 with the same power plant (LT1).
I can't foresee the the ZL1 beating the Z06 down or on a track due to the aerodynamics and other aspects that the Vette has over the Camaro. I hope that clears it up. |
