![]() Drives: 2016 2SS Blue Velvet Metallic Join Date: May 2016
Put in 10 Qts of oil
Just had the first oil/Filter change done at 602 miles. 10 Qts of Mobil1 5W-30 added but the dip stick indicates at the half way mark. Seems kinda off odd but I know for certain 10 Qts went in.
Retired from Car mfrs....
Take a level check in a few days… If it's mid stick, is perfect
Toyota Tech
Drives: 2SS A8 Join Date: Jul 2014
let it sit for about 3 to 5 minutes n check it
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114 Sold 2013 Chevy Crzue LTX |
![]() Drives: 2016 Camaro 2SS (on order) Join Date: Mar 2016
Correct. Go eat some lunch, come back, and it should be readable.
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC, Nav, Sunroof, Loaded "Ahhh! Take care to get what you like or you will be forced to like what you get!" - Lyrics from a song from Scooter: "Apache Rock the Bottom!" Previously owned 1998 BMW 540 w/M-series package 1991 Trans Am GTA 1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn) 1985 Firebird (R.I.P.) 1976 Camaro LT |
![]() ![]() Drives: 2016 Camaro 2SS 6SP/Suby Legacy 6 Join Date: Oct 2015
It levels out...
TFPK40
Its Here! Finally came home on 3-31-16! Red Hot 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Silver Rally Stripes, NAV, Sunroof, 56W Split Spoke Wheels, Body color Hood vents, Body color Splash Guards and winter protection package. Ordered 1-28-16: 1100 2-11-2016 :2000 2-15-2016: 3000 TPW of 3/7...That went quick! ![]() 2-26-2016: 3400 Status TPW 3/7 3-5-2016 : 3800 3-8-2016 : 4300 3-11-2016 : 4B00 3-15-2016 : 4200 3-22-2016 : 4800 3-29-2016 : 6000! |
![]() Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
Did you put oil into the filter first and let it absorb - because you can put close to 10 oz in before it fully absorbs and starts to fill up.
#7 |
![]() Drives: 2015 Porsche BGTS, 2016 2SS Join Date: Oct 2013
Half way up on the hash marks is perfect. In fact, as long as it reads within the hash marked area you're good to go, absolutely no need to be at the top of the range with a 10qt system.
I did exactly the same, used 10qts exactly, including the oil I primed the oil filter with and its right smack in the middle. |
#8 |
Priming the filter has no effect on the level checked after the engine is run. Perhaps, if you put the filter on dry then put oil into the motor to get a top hash mark reading it would have an effect but that's not how you change the oil. Once you've run the car for a few minutes then let it sit for a few minutes everything is stabilized which is when you get the proper reading, primed filter or not.
