Old 05-31-2016, 08:53 AM   #1
Yankees1
Drives: 2016 Camaro SS - Nightfall Gray
Hooking up a Battery Charger
After realizing where the battery is located, I want to hook up my Ctek charger. I won't need it till the winter, but it looks like the best way is to use the eyelets and let the comfort connector hang out of the "trap door".
My question is how do you get to the positive terminal? There is no way my hand can get to it through the opening. It looks like you have to pop out some plastic rivets and then the entire side comes off.
I am at the age where I like to ask before I try.... Thanks....
Yankees1 is offline   Reply With Quote
Old 05-31-2016, 09:04 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I assume you're hooking up a charger because you're going to leave the car for a while in storage? The battery will last quite a long time, months and months, if you just detach the negative cable that you're seeing right in front of you. Just wrap it in a baggie, you don't lose any settings and the only thing you lose is the window indexing, Which when you hook it back up will tell you to roll the windows down, then roll back up. That's it. Also for shorter periods see my post in the electronic section about the "transport mode".
Old 05-31-2016, 09:05 AM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
There's a positive and ground post in the engine bay by the fuse box.
nancygrl is offline   Reply With Quote
Old 05-31-2016, 09:10 AM   #4
MovieGuy
MovieGuy's Avatar
Drives: 2016 Camaro 1LT
Look at page 314 of your owners manual. I don't know why you couldn't charge your battery or even disconnect it from that same spot.
http://www.camaro6.com/forums/image.php?u=115947&type=sigpic&dateline=1461721697
Life after retirement
MovieGuy is offline   Reply With Quote
Old 05-31-2016, 09:16 AM   #5
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Disconnecting The front ground wont disconnect the whole batt, i asked here a few months ago and was told rear fuse box would stay energized. To make the whole car dead, you need to pull the neg cable behind the trunk access door.
Old 05-31-2016, 09:28 AM   #6
MovieGuy
MovieGuy's Avatar
Thankyou. But you can charge it from there? I am lost without a schematic but it seemed to me this was a direct line to the battery.
Old 05-31-2016, 09:32 AM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
You certainly can charge/jump from the front, but because I like things direct, I'd pull the entire panel as it's all just pushpins, and add a pigtail on the batt.....for a charger to run thru the trunk door access panel
Old 05-31-2016, 12:35 PM   #8
The1DoubleN
Drives: Blown up '16 SS
Yes, I have a trickle charger on there all the time and just leave the hood cracked since my car gets driven about 1-2 days a week only and the voltage drops to about 50% in 3-5 days in normal temperatures. Best way to make your battery last is to keep it on a good trickle charger unless you're driving it everyday, then it's not really necessary, provided you're driving at least 20-30min....
The1DoubleN is offline   Reply With Quote
Old 05-31-2016, 02:10 PM   #9
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Glen e, you seem to have window indexing in your 2LT and it seems absent in my 1LT, do you think it is part of the lighting/convenience package, which I do not have?
Laborsmith
laborsmith is offline   Reply With Quote
Old 10-26-2016, 12:28 PM   #10
Kenster865
Drives: 2017 Camaro SS (1SS)
Hi Folks!
I'm new around here. Just picked up a 2017 SS (w/1SS trim). As I don't plan on driving it during the week I want to keep the battery charged up. I have a CA-approved battery tender that I've used on a 2007 Toyota RAV4 that I own and it works really well.
I was hesitant to utilize the jumper nodes in the engine bay and called my dealership to check their thoughts on doing that. The service adviser cat I spoke with says not to use those nodes for a battery tender, that it could cause damage to some of the fuse box items. What do you guys think about that? I got brave having read through this thread and lo and behold - it works!! Now I haven't tried to start the car yet but everything appears to be functioning fine.
So was this adviser guy full of it or is there a real concern that he was raising? Thanks in advance for the helps. Happy cruising, y'all!
Kenster865 is offline   Reply With Quote
Old 10-26-2016, 12:33 PM   #11
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Originally Posted by Kenster865 View Post
Hi Folks!
Considering you can jump a car from the front posts (according the manual), I would say he is full of it. Jumping will put a lot more power through it than a trickle charger.
Old 10-26-2016, 12:34 PM   #12
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
A tender is fine thru the front......
Old 10-26-2016, 12:38 PM   #13
camaromike77
camaromike77's Avatar
Drives: S O L D
Pretty much ditto here. I have a trickle charger on it as well, but ran the wire through the hood "vent", then wrapped it in a cloth so my hood is completely closed. Mine went off the road last week, and will be stored in my garage until late March, or until the snow/salt is gone.
Added fuel stabilizer, hooked up battery tender, placed indoor cover on it, and this weekend I will be removing the tires and placing the vehicle on jack stands. Winter SUCKS.......
Club F1FTY
Old 10-26-2016, 12:44 PM   #14
whiteboyblues2001
whiteboyblues2001's Avatar
Okay, I know nothing about winterizing a car.... so, please be patient with my stupid questions, but...
When you say you will remove the tires, do you mean you will remove the wheels from the car, or remove the tires from the rims? And why would you need to do this?
My 1SS is my daily driver, but I will be getting winter tires on separate wheels. When I store the wheels/tires that are not being used, what do I need to do so they don't have issues?
Thanks!!
whiteboyblues2001 is offline   Reply With Quote
