Old 05-27-2016, 12:36 PM   #1
LordKevin
Drives: 2016 Camaro 2ss Red Hot
Is this really the procedure for this...
So I have a vibrating noise coming from the rear at low speed turns. I know this is a known issue. The dealership says they have to replace the fluid then drive 25 miles come back after. Drain the fluid and replace it again then drive another 25 right after. That sounds very annoying. Is this really what I have to do to fix the issue?
LordKevin is offline   Reply With Quote
Old 05-27-2016, 03:32 PM   #2
Ian SS
Ian SS's Avatar
Drives: 2016 1SS, 2017 JKU Wrangler
Well that is a differential problem. They are probably trying to figure out if the diff is mechanically bad or if they can fix it by running clean fluid through it.
SLO 1SS - sold
1SS MRC NPP 6MT
2018 Ram Rebel 4x4 5.7
Ian SS is offline   Reply With Quote
Old 05-27-2016, 10:12 PM   #3
godeepdown
Jeremy Frye
godeepdown's Avatar
Drives: 2016 Hyper blue 1SS
I have heard of this as being the fix to some of the diff issues they are having. Some thing to do with proper lubing of the clutch plates.
godeepdown is offline   Reply With Quote
