Old 05-26-2016, 08:16 PM   #1
ender2664
Drives: 2016 2SS
Npp open time
I have read some threads about pulling the fuse vs track and have one question:
How quickly does the valve open?
I assume when I'm sitting at a light in track mode the valve is closed. If I Rev at a car while at the light does the valve open quickly enough so exhaust will be heard as open? Or does the valve not open that quick?
ender2664 is offline   Reply With Quote
Old 05-26-2016, 10:54 PM   #2
raptor5244
Drives: 2022 CT4-V Blackwing
The NPP valves are pretty much wide open in Track and Sport mode while at idle. You will definitely hear the exhaust as you accelerate from a stop. They tend to close up when you are just cruising at low rpm at idle. If you pull the fuse they never close up.
Old 05-27-2016, 11:36 AM   #3
JFM-jr
JFM-jr's Avatar
It closes in track mode at partial throttle at highway speeds. It is open when at idle the area you will notice the fuse pulled is when on the highway cruising. You will be able to hear the AFM valves opening and closing alot better as well if your an automatic.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 05-27-2016, 11:43 AM   #4
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
just pull the fuse and enjoy. there is not con to doing so. but be sure its in track mode when you do the fuse pull, if you pull the fuse in tour/stealth, the valves will be closed only.
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 05-27-2016, 12:29 PM   #5
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
Not my experience. The default for the valves is OPEN. It's the algorithm in whatever mode you're in that closes them. That requires power (fuse in)
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 06-01-2016, 01:55 PM   #6
Dmagg0802
Dmagg0802's Avatar
Drives: 1969 Z/28 2013 LT 2016 2SS
Pull fuse while car is running or off?
Dmagg0802 is offline   Reply With Quote
Old 06-01-2016, 02:17 PM   #7
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Make sure the car is turned off.
I have my fuse pull, love it! And the valve still stay open FOREVER lol
You can try toggling all the track modes, no difference in sound and you know that you will have the loudest sound available.
It's really only loud the first minute or two upon a cold start up... then it'l ease down and stay that way.
Richard0nee is offline   Reply With Quote
Old 06-02-2016, 10:21 AM   #8
obarry13
obarry13's Avatar
I have one question with this, doesn't the valve have to do with your mpg or is that all to do with the engine? Only reason I ask is every time the vehicle changes from V8 to V4 mode, the valve closes as well, which would mean a difference of 17mpg to 32mpg on the highway.
obarry13 is offline   Reply With Quote
Old 06-02-2016, 12:20 PM   #9
raptor5244
Nothing. The auto transmission Camaros with NPP have an extra set of valves in the exhaust that only activate when you are in AFM (V4 mode). The point of these AFM NPP valves is to eliminate the undesirable exhaust note when in V4 mode.
The Gen5 Camaros with auto trans got the L99 motor and did not have NPP as an option. This was one of the main reasons. No AFM valves to control the V4 mode exhaust note. So, folks usually had to tune out AFM on the L99s if they wanted an aftermarket exhaust to sound good all the time. The LS3 in the manual tranny Gen5s did not have this issue since there was no AFM to speak of on the LS3. The difference though was that the LS3 based NPP exhaust used vacuum control to close the valves instead of the electronic controlled valves on the Gen 6 NPP. On the Gen5 LS3 manual cars the NPP valves would be open at idle and then would close at low and cruising RPM but once you put your foot in it at about 3000rpm or so they would open up again to redline. Some like to pull the fuse even on the GEN5 NPP cars so that is was louder in that 1500-3000rpm range.
The GEN6 NPP offers more control with the settings with Stealth, Tour, Sport and Track. These profiles basically control how much and how long the rear NPP valves stay open. If you pull the fuse the rear NPP valves never close but the AFM valves to stay in sync with AFM mode. I am doing this now on my car since the darn NPP rattles on me in the other modes. If I keep the fuse pulled it work pretty good for me with the A8 since the AFM will kick in while cruising and the exhaust will be quiet but once I get on it it roars to life.
Once I get confirmation that there is a real fix or new design of the rattling NPP I will take it in to get it fixed/replaced.
Old 06-02-2016, 01:33 PM   #10
obarry13
obarry13's Avatar
Gotcha that makes sense. So the chirping valve when my car changes from V8 to V4 would be the AFM valves then? Brought it in to be fixed a month ago and all they did was lube it and it is chirping again.
Old 06-02-2016, 07:45 PM   #11
raptor5244
Does it chirp with the rear NPP Fuse pulled? Fuse 51. If so, then the only valves that can move are the AFM NPP valves, There is a fuse for the AFM NPP valves as well that you can pull if you wanted to verify but I heard that will throw a check engine light if you pull it. I saw the TSB that says to spray the Dry Slide lubricant in the NPP valve assembly...annoying for sure.
Old 06-06-2016, 02:55 PM   #12
obarry13
obarry13's Avatar
So I pulled Fuse 51 this weekend. It is definitely the AFM valves that are causing the squeak/chirp when it switches from V8 to V4. I have to say, I am loving the sound while driving/coasting now though!
Old 06-06-2016, 07:08 PM   #13
ReFLeX135
ReFLeX135's Avatar
Drives: 2017 Camaro 1SS
I noticed this same exact situation occurring, and pulled the fuse too. It occurs from V8 to V4 still. However, I noticed that, when going around 25 mph in 3rd gear (auto shifts to 3rd at this speed), if I slow and down shift into 2nd manually I can reproduce this chirp. Makes me wonder what's really going on.
Hyper Blue | A8 | NPP Dual Mode Exhaust
ReFLeX135 is offline   Reply With Quote
Old 08-28-2016, 06:52 PM   #14
mojman2001
mojman2001's Avatar
Drives: 2016 Camaro SS2
NPP Exhaust
To me I've notice the clutch is more responsive in track and sports mode or is it just me? But my question is does the m6 have afm valves? Or is just automatics? 2. Whats the best exhaust with aggressive sound to it. I have my eye on blackheart hookers, but i wish Masterflow would make npp exhaust for the outlaw series. I had that on my 2013 ss love the sound to it and it was aggressive, but loud. That was stock headers and cats..
mojman2001 is offline   Reply With Quote
