Old 05-24-2016, 08:38 PM   #1
ReFLeX135
ReFLeX135's Avatar
Drives: 2017 Camaro 1SS
[Video] Is this A8 park to reverse shift normal?
Stare at the nose, or the chevy emblem on the front, specifically at 0:07.
EDIT: New (video, closeup)
Originally posted this video:
https://youtu.be/rG6uZdXV2y8?t=6
I start the car, shift into reverse. I then shift into park and go back into reverse again.
Partly due to a worse version of this video (and shift problems), the transmission was replaced at about 500 miles. Car has 1500 miles now and it is returning. Sounds quite loud when it shifts in also. Very obvious inside the car.
Is this normal?
Hyper Blue | A8 | NPP Dual Mode Exhaust
ReFLeX135 is offline   Reply With Quote
Old 05-24-2016, 08:48 PM   #2
DenverTaco07
DenverTaco07's Avatar
doesn't seem that bad to me...go to dealer lot, do same proceedure and see.
Old 05-24-2016, 09:05 PM   #3
ReFLeX135
ReFLeX135's Avatar
Yeah it's not nearly as bad as the original trans, but it seems to be progressively getting worse. I'll check out another SS like you said, thanks. I'll try to get a better video too. Doesn't look the same here as in person.
Old 05-24-2016, 09:10 PM   #4
BadBillyJack
Drives: 2016 2SS Camaro
Seems a bit excessive. The dealership probably needs to relearn the trans shift adapts again. If they even did it the first time around.
2016 2SS Nightfall, A8, NPP, MRC, Jet Black leather.
Originally Posted by 20171LE View Post
The fact remains, the Camaro designers have another fail in not transferring the clothes hanger from the ATS to the Camaro.
I, and every other Camaro owner that hangs clothes in their cars, need a solution.
BadBillyJack is offline   Reply With Quote
Old 05-25-2016, 02:02 AM   #5
Libra Red
Libra Red's Avatar
Drives: 2016 Garnet Red 2SS
Yeah... mine doesn't do that.
Libra Red is offline   Reply With Quote
Old 05-25-2016, 05:45 AM   #6
ReFLeX135
ReFLeX135's Avatar
They said they did it a couple of times before and after the new trans. Maybe they didn't do it right, which seems about right for these dealers lately.
Thanks for the input!
Old 06-21-2016, 06:25 PM   #7
ReFLeX135
ReFLeX135's Avatar
Here's a new video with better lighting a better angle:
Old 06-21-2016, 06:47 PM   #8
CapeCruisin
Daily Driver 24/7 365
CapeCruisin's Avatar
Drives: '15 CRT 2SS/RS/1LE
that's not normal.
NPP Fuse Pull, Z28 CAI =
Previous Rides:
2005 Magnum R/T A5 CAI, Cat-Back
2014 RRM Camaro 1LT/RS A6/NPP CAI
Follow Me On Instagram!
CapeCruisin is offline   Reply With Quote
Old 06-21-2016, 06:51 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Mine doesn't shift into reverse even remotely that hard. Are you shifting into reverse right after start-up while the rpms are still high?
Jared Royce
801.545.4215
JDP Sales is offline   Reply With Quote
Old 06-21-2016, 06:55 PM   #10
ReFLeX135
ReFLeX135's Avatar
Jared Royce
801.545.4215
This exact shift in the outside video was after driving 13 miles home and parking, leaving the car on, going inside to grab the camera, and filming the shift.
Old 06-21-2016, 06:59 PM   #11
JDP Sales
JDP Sales's Avatar
Yeah, i'd be concerned.
Old 10-26-2017, 02:12 PM   #12
hyper_blue_2ss_camaro
hyper_blue_2ss_camaro's Avatar
Drives: 2017 Hyper Blue 2SS
Jared Royce
801.545.4215
Sorry to resurrect an old post, but what happened with this? I'm experience this issue on my 17 2SS A8.
hyper_blue_2ss_camaro is offline   Reply With Quote
Old 10-26-2017, 02:19 PM   #13
Blazin383
Blazin383's Avatar
Drives: 2016 SS
I’ve got about 10,000 miles on mine and I don’t tbink I’ve ever experienced that, but I’ve never stood outside the car to watch it. I’m guessing it feels as bad or worse in the car as it does outside so I’d get it looked at again!
Blazin383 is offline   Reply With Quote
Old 10-26-2017, 02:37 PM   #14
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
That’s Differently not normal. It should be smooth and hear nothing. That should be fixed or whole car returned if they can’t fix it by the third time.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
