Old 05-23-2016, 05:58 PM   #1
Jmansize13
Jmansize13's Avatar
Drives: 2015 Corvette Stingray
Low PSI message
So I just went to take my SS for a spin and got a low PSI message. Rear driver is at 3 PSI.I know tires are covered under GM warranty. Does that include road hazard? I'm taking it in tomorrow, just want to get my ducks in a row.
Jmansize13 is offline   Reply With Quote
Old 05-23-2016, 06:01 PM   #2
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
No it won't include road hazards. The road hazard wheel/tire warranty is the best thing I've ever purchased in finance. It always pays off.
Eric SS is offline   Reply With Quote
Old 05-23-2016, 06:01 PM   #3
laynlo15
Drives: 2022 Lt1 A10
No, doubt they'll cover it.
Old 05-23-2016, 06:19 PM   #4
activepat
activepat's Avatar
Drives: Red Hot SS 1LE
It is a flat. Good luck with the warranty.
Oh, and this is right up there with the Bimbo and the hair tie.
activepat is offline   Reply With Quote
Old 05-23-2016, 09:30 PM   #5
mjw930
Drives: 2015 Porsche BGTS, 2016 2SS
Tires aren't covered by GM, they are covered by the manufacturer and NO tires is covered for road hazard without buying an insurance policy. The dealer policies bought from the finance guy are rarely the best deal. The best program out there is Discount Tire. Most stores will sell a road hazard warranty called a certificate for about $50 / tire for the SS tires.
mjw930 is offline   Reply With Quote
Old 05-23-2016, 09:57 PM   #6
SSSHYBOY
Drives: 2SS convertible, black,black
Thanks "mjw"; I will check that out tomorrow... Right price.
A little known fact. Women with extra pounds, tend to live longer than men who mention it.
SSSHYBOY is offline   Reply With Quote
Old 05-24-2016, 04:22 AM   #7
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Road hazard, never lease/purchase without it in my opinion.
Old 05-24-2016, 07:09 AM   #8
ctrlz
At 3 psi you cannot drive too far on a run-flat without losing sidewall strength. The range is dependent on speed (driving on the flat) and will be further limited if the tire went flat due to a sidewall tear or puncture. If the tire is repairable, it will have reduced range if it goes flat again.
Make sure your service tech is well-informed on these limitations.
The maximum range to drive on a run-flat is often quoted as 50 miles.
http://www.popularmechanics.com/cars...ires-17069881/
Old 05-24-2016, 06:01 PM   #9
Jmansize13
Jmansize13's Avatar
Hey guys thanks for the help.
Dealer found a nail in the tire and was confident patching instead of replacing.
I only drive about a mile on flat before I added air to drive another 5 miles to the dealership. Hopefully it works out....
Old 05-24-2016, 06:04 PM   #10
BFella
BFella's Avatar
Drives: 16' Supercharged 1SS
Does uneven wear due to misaligned rear come under warranty?
BFella is offline   Reply With Quote
Old 05-24-2016, 06:19 PM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
Probably note. Generally the alignment is not warrantied.
Old 05-24-2016, 07:51 PM   #12
mjw930
You should be good to go.
Old 05-24-2016, 07:52 PM   #13
mjw930
Actually, the dealer will check and correct the alignment in the first few thousand miles under warranty once. Some dealers want more than 1000 miles on the car so it's settled, others don't care.
Old 05-25-2016, 03:01 PM   #14
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Hopefully it is a nail or something that can be patched. Let us know the outcome.
Sledgehammer70 is offline   Reply With Quote
