![]() Drives: 2016 Camaro 2SS NFG M6 MRC NPP Join Date: Mar 2016
I was able to successfully set up a switch connecting to fuse #51 by following the thread (http://goo.gl/CXC30n) created by 'Theta' from 'corvetteforum'. This thread only shows how I installed it on my 2016 Camaro. Feel free to get even more creative beyond my easy route!
Total amount spent: ~$20-25 Lumision ADD-A-CIRCUIT ATR MICRO2 FUSE - $7.99 (Used spare fuse to create a custom spade-terminated wire that goes into the lower right slot) http://www.amazon.com/gp/product/B00OZGA8O8 16 Gauge primary wire - $7.49 (Cut equally in half) http://goo.gl/MMkihm Dorman Conduct-Tite - $3.99 Rocker Switch (I didn't connect the copper terminal for the LED light since it's not required) http://goo.gl/MLDyNl Black Electrical Tape - ~$3 Video of switch in action: https://youtu.be/3NsOFOHUri8 |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2016
Sorry, great idea, but the execution reminds me of the kids in high school who routed their amp wires trough their doors because they didn't want to find a better place for it.
Retired from Car mfrs....
my god , use some slit loom, wires as is, look tacky going across engine...
#4 | |
Slit looms will be my next step. Due to time, this was my test set up and will refine it later. |
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
I did a wireless version. Removes in 10 seconds for warranty work. I love it so much better than the stock function
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
![]() Drives: 2019 Camaro 2SS 1LE in Orange Crush Join Date: Dec 2014
Can you share your wireless version?
Current
2019 Camaro 2SS 1LE in Orange Crush Past Cars that Matter 2007 Mustang V6 (4.0)(Auto) 2008 Mustang GT (4.6)(Stick) 2010 Mustang V6 (3.7)(Auto) 2011 Challenger R/T (5.7)(Stick) 2015 Corvette C7 (6.2)(Stick) 2015 Mustang GT (5.0)(Stick) 2016 Corvette C7 (6.2)(Stick) 2017 Daytona 392 (...6.4)(Auto) |
#7 |
![]() ![]() Drives: 2002 z28, 2023 Zl1 Join Date: Sep 2012
I’ve seen theses but don’t know if anyone had tried them
https://www.ebay.com/i/162949355329?...26pg%3D2385738 |
#8 |
![]() Drives: 2017 1ss 1le Join Date: Sep 2015
some hackery going on here
#9 |
BAMF SS
Maybe adding this to a car not originally equipped with NPP but has an NPP exhaust from another car on it would be beneficial. But ummmm if you car has NPP from the fsctory..... you know there is a factory switch in the center console and you can also change it in the radio, right?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#10 | |
![]() Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
Setting the NPP exhaust in the "track" setting, will not keep the flaps open at all times. I was contemplating buying an aftermarket axle back until I tried removing the fuse (fuse #51). I was skeptical at first. But saved me a ton of money. I can definitely see the point in a switched fuse. At some times the "stealth" mode would be nice. |
#11 |
![]() Drives: 2018 Camaro ZL1 Summit White Join Date: Apr 2018
Look up the mild to wild controller, I wired up mine and can be installed/removed in a few minutes.
Also have it paired to my home link garage opener so I can turn the fuse on or off from inside. |
#12 |
![]() Drives: 2016 Camaro 2SS Join Date: Dec 2015
I was looking for the same clean installation about a month ago. Wasn't able to find anything that would look good. The mild to wild controller looks like it would be easily to install and looks good. If I found the mild to wild controller last month, I would have probably installed it.
My car is tuned with HP tuners. I found that you have control over NPP with HP tuners. I have my track mode setup completely open. I changed my tour mode to start up quietly without the rumble like stealth mode. I usually drive around in track mode and the car reverts to tour mode when you shut it off. I like this because it is quieter on start up. Better when I leave for work at 6am. I put in track mode after I get down the street. Sport stays in sport mode after shutting the car off. I left sport and ice mode with stock settings. |
#13 |
![]() Drives: 23 Zl1 Join Date: Apr 2019
If anyone executes this its a good idea to have the wire go down (twords the ground) before entering the fuse box. Waters natural progression will lead right to it with that run. You can also run the cable from the bottom of the fuse box up into it.
Fish tape is yo friend. |
