Old 05-04-2016, 12:43 PM   #1
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
Rattles! AAARRRGG
Let me start by saying that I love this car. Fast, fun, comfortable, and refined.
2LT RS V6 manual trans
I have a couple rattles that have developed and are bothering the hell out of me.
The most annoying is the door panel rattle. Even at low volumes there is a rattle caused by the woofers (bose system). Pressing firmly on the knee bolster or arm rest stops the rattle. But, of course it's impossible to drive that way.
The 2nd rattle is an odd one. In 3rd gear under moderate to full throttle there is a pronounced rattle from the stick shift. It doesn't sound like the stick itself but applying gentle pressure forward on the stick eliminates the rattle.
Does anyone else have these same rattles? Have you tried to fix them? I'd rather not have the dealer fix these small problems as I don't trust them not to damage something in the interior when tearing into the car. I'll probably try to find my trim tools and try to fix them myself.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 05-04-2016, 01:16 PM   #2
Luigi91
I have the same vibration rattle in my drivers door. It makes me hardly even want to listen to music it's so annoying. When my car goes in to get the rear diff replaced I will have them fix it.
Luigi91 is offline   Reply With Quote
Old 05-04-2016, 09:44 PM   #3
DougCBJ
Drives: 2016 Blue 2SS
I have the rattle on the driver door. It sounds like it was coming from the power window adjuster knob. My wonderful dealership's solution was to adjust the stereo settings and turn down the bass, which hasn't solved the problem.
DougCBJ is offline   Reply With Quote
Old 05-17-2016, 01:21 PM   #4
cryssm
cryssm's Avatar
Drives: Car
Sorry to bring up a somewhat old thread, but I am having the same rattle come from my shifter. It's most noticeable in the range of 2-3k RPM, in 2nd and 4th gear; although, it can be heard at times in other gears and outside that rev range, but never in neutral. I have an appointment tomorrow at the dealership to have it looked at; I will report back what they find!
the one and only
cryssm is offline   Reply With Quote
Old 05-17-2016, 03:38 PM   #5
grnflash
grnflash's Avatar
Drives: Hard
Originally Posted by cryssm View Post
…I have an appointment tomorrow at the dealership to have it looked at; I will report back what they find!
Please do… I've been trying REAL hard to ignore mine over the last 6 weeks!
'16 2SS, 6MT, MRC, NPP, sways, square 285's—and an ear-to-ear grin!
grnflash is offline   Reply With Quote
Old 05-17-2016, 03:48 PM   #6
samsumon
Drives: 4 wheels
Same rattles on the driver side and i met someone with the same complaint.
samsumon is offline   Reply With Quote
Old 05-17-2016, 06:05 PM   #7
myrally1
myrally1's Avatar
Drives: 2016 summit white 2ss
same here driver door rattle and a mysterious rattle from the dash
summit white npp,mrc,8a
myrally1 is offline   Reply With Quote
Old 05-18-2016, 06:44 AM   #8
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
Found a possible bulletin on the shifter rattle.
Rattle Noise from Manual Transmission Shifter - (Mar 15, 2016)
Condition:
Some customers may comment that the shifter knob is rattling.
Cause:
This condition may be caused by a loose shifter knob retaining screw.
Correction:
If the shifter knob retaining screw is found to be the cause, the fastener needs to be torqued to proper specifications.
Using a flat-bladed trim tool, detach the transmission control lever boot from the console.
 2. Lift the transmission control lever boot to access the shift knob fastener 
 3. Remove the fastener.
 4. Apply thread locker, GM P/N 12345382 (In Canada, use 10953489), to the shift knob fastener and install.
Tighten
Tighten the fastener to 7 Y (62 lb in).
 5. Install the transmission control lever boot  to the console.
Dont know if this is what your hearing, but thought id at least mention it.
Lucely Engineered is offline   Reply With Quote
Old 05-18-2016, 05:33 PM   #9
cryssm
cryssm's Avatar
Drives: Car
Condition:
Cause:
Correction:
Tighten
Thank you much! This service bulletin made my trip to the dealership very smooth.
It wound up being exactly what the service bulletin stated. It's an issue with the knob of the shifter, and upon them performing the fix outlined in the bulletin, the rattling has stopped. The bulletin was viewable to the service advisor at the dealership, as well. It's much more peaceful now driving without hearing that rattle!
the one and only
Old 05-19-2016, 07:08 AM   #10
Lucely Engineered
Glad i could help.
Old 11-22-2016, 02:26 PM   #11
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Any updates on the driver door rattle?
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
Old 11-22-2016, 02:55 PM   #12
BlueCamaro6
BlueCamaro6's Avatar
Drives: 2018 Camaro 2SS, Hyper Blue
Dealer blamed door rattle on "high bass level" but you can hear it at low volume. So that's clearly BS. I did find if I put my finger on the little oval vent looking piece on the door it goes away. I haven't looked into it any further than that as I have other issues with the rear diff I'm dealing with.
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback)
1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk
BlueCamaro6 is offline   Reply With Quote
Old 11-23-2016, 12:38 PM   #13
vaspen
vaspen's Avatar
Drives: 2017 l4 blue 6speed
there is a service bulletin for the issue I had mine in for it they use some typ of Velcro tape took a lot of the rattle out but not completely gone
so take your car in and ask about it
vaspen is offline   Reply With Quote
Old 11-25-2016, 05:32 PM   #14
Boone
Unbowed, Unbent, Unbroken
Drives: 2017 Camaro 2SS 50th Anniversary
Sounds like the driver door rattle is a common thing that has bit me too. Now I have to take mine in too.
Current:
2017 Camaro 2SS 50th Anniversary Package
Previous:
1999 Camaro Z28
1992 Camaro RS
Boone is offline   Reply With Quote
