![]() Drives: 2016 Camaro 2SS Join Date: Apr 2011
Squeaking noise while turning
Have any of you experienced a squeaking noise while turning or taking a curve? At first it was a very faint noise and I attributed it to just a rattle but then I noticed that the sound is only made when the wheel is turned while driving through a curve. Now I am starting to hear the same squeak when I turn the steering wheel into a turn.
Any thoughts?
2016 Nightfall Gray 2SS A8 NPP Low Gloss Black Wheels
#2 | |
![]() Drives: 2016 Camaro 2SS Join Date: Oct 2015
Ordered: 2SS Nightfall Gray, NPP, MRC, navi, auto, low gloss black wheels, black bowties
TCFCB4 1000: 12/08/2015 2000: 12/08/2015 3000: 12/10/2015 3000: 12/12/2105 - TPW 1/11/2016 3100: 12/18/2015 - TPW 1/18/2016 3300: 12/23/2015 - TPW 1/11/2016 3400: 12/24/2015 3800: 01/19/2016 4300: 01/20/2016, 4200: 1/28/2016, 4300: 1/29/2016, 4B00: 1/30/2016, 4200: 2/7/2016 (train), 4800: 2/19/2016, 5000: 2/22/2016, 6000: 2/25/2016 |
Also, are cars are the exact same. Good choices.
Ha!! They are the exact same. No it's not during a cold start it's a consistent noise.
Also didn't see any post about this issue in the issues thread.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Mine has had a squeak for a while, usually when coming to a stop/slowing down, even before I step on the brake pedal. Sometimes when turning as well. When I had my car in last week for the A8 issue and to check the oil pan tube retention recall, I asked them look into the squeak. They couldn't determine what was causing it, so I let it go for now. I can live with the squeak for now, but it is annoying.
#7 | |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
I am having the exact same squeak, and same as you, they couldn't diagnose it either. hmm... anyone else?
#8 |
yeah low speed squeek from passenger rear.. mostly wile turning slow..started around 1500 miles.
#9 |
The BEAST
same, I think I hear it from the right, but I cant tell if front or rear right.
#10 |
It appears to be on the right side, but could be more centered as well...hard to really pinpoint location. It is usually just 1 short squeak, pretty loud. It is usually on turning while slowing down, or when driving straight and slowing down, even before the brakes are pressed.
#11 |
I can't figure out what it could be. First thought it was the known rear end issues, don't really think it is that. Not a NPP issue, don't think. It is not a brake issue...kind of annoying at this point.
#12 | |
The BEAST
#13 |
Well at least I am not crazy now! lol...If it gets any worse or if anyone stumbles upon the source of the squeak, then I will bring it in. For now I am fine, especially having the A8 just reprogrammed, car is driving awesome now.
#14 |
The BEAST
hmmm mine's a manual, so that may rule out the tranny. wonder what it could be? if it does get worse, I will be back to the dealership as well.. I'm just hoping that its not a sign of some major issue.
