Old 04-27-2016, 08:08 PM   #1
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Can I delete my EGR valve?
2001 Suburban... Lately, going over bumps, my dash lights will sometimes flicker, and the car stutters and ALMOST stalls. I have discovered some sort of short around the plug to my EGR valve. Wiggling this thing around replicates the dash light/ stall problem. However, when I completely unplug the EGR valve, the problem does not occur.
What would be the harm in leaving it unplugged? Will it damage anything, harm anything, or will it simply not run as efficiently?
Thanks,
Ken
Scalded Dog is offline   Reply With Quote
Old 04-27-2016, 11:04 PM   #2
Bhobbs
Bhobbs's Avatar
I'm pretty sure EGR is part of the smog control system. You would need it functioning to pass smog.
Old 04-28-2016, 12:48 PM   #3
derklug1
derklug1's Avatar
Drives: 2016 GT350
Check the ground wire on the back of the passenger side head. Real common problem and causes what you are describing.
"Life is hard, it's harder if you're stupid" John Wayne
derklug1 is offline   Reply With Quote
