Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V8 Bolt-Ons & Tunes
Old 04-26-2016, 03:59 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: 6th Gen Camaro SS Borla S-Type Axle-back 11920 No dual mode
2016-2018 6th Gen Camaro SS Borla S-Type Axle-back 11920 No dual mode
Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gases, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds.
Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship.
This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used).
- Rear Section Dual Exhaust System
- 2.75" into muffer dual 2.5" out
- Will fit vehicles equipped with Dual Mode Exhaust (NPP) but does not include Dual Mode valve
Check it out here: 2016 6th Gen 2016 Camaro SS Borla S-Type Axle-back 11920 No dual mode
southerncarparts is offline   Reply With Quote
Old 04-13-2023, 02:17 AM   #2
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...de-p-8803.html
