Old 04-21-2016, 01:57 PM   #1
Jmetc89
Jmetc89's Avatar
ANC cancellation bose system
2016 camaro 2ss w/ bose system
looking to upgrade the entire sound system
anyone find a solution to get rid of the ANC without screwing anything else up?
Jmetc89 is offline   Reply With Quote
Old 04-21-2016, 02:28 PM   #2
tecboy
tecboy's Avatar
The only way to get rid of ANC is to disconnect the 2 mics at the Bose amp...and with regards to upgrading entire system...good luck...the signal between the head unit and the Bose amp is using proprietary MOST communication...no one makes a converter...I am hoping ******** comes out with some sort of wiring adapter to add a connection for a sub amp to add a separate subwoofer to the system..
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 04-21-2016, 02:49 PM   #3
Modshack
Modshack's Avatar
Drives: 2SS, Hyper Blue
If you're trashing the entire Bose system, why would this be an issue???
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav
Modshack is offline   Reply With Quote
Old 04-21-2016, 02:59 PM   #4
tecboy
tecboy's Avatar
Unless you are doing away with the MyLink "headunit" in the dash.....the output of the factory MyLink system is MOST....there is no way to convert the audio out of the head unit to connect to aftermarket amp
Old 04-21-2016, 03:23 PM   #5
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
The x3 connector gets rid of ANC but you lose:
Rear cross traff alarm
Turn signal clicks
I like cross traff so i reconnected
Old 04-21-2016, 03:24 PM   #6
Jmetc89
Jmetc89's Avatar
I was just going to get the microphone wires cut, not disconnect the entire connector
Old 04-21-2016, 05:07 PM   #7
ctrlz
There is an engine rpm signal feed as well. It's mentioned in another post here somewhere. I got the impression the data is used for both ANC and speed sensitive volume.
Old 05-08-2016, 08:16 PM   #8
ctrlz
Here are two articles I found on Bose ANC:
http://articles.sae.org/12747/
http://blog.nxp.com/connected-car/nx...-quieter-cars/
Note this system targets engine noise and aims for up to a 20 dB reduction. It does not address road noise, which is apparently a much more complex problem.
From what I can tell the system is marketed as "Active Sound Management" when the Bose amp is paired with the NXP SAF77x chip in the head unit. I suspect that chip is not present in the Camaro head unit, since they call it "active noise cancellation" with all lowercase letters in all the product info.
Old 05-08-2016, 11:25 PM   #9
ender2664
Drives: 2016 2SS
So if I turn off the ANC does the car sounds noticeably different?
ender2664 is offline   Reply With Quote
Old 05-09-2016, 10:27 AM   #10
ctrlz
I don't have one yet (a Camaro, that is), and I have been wondering about that. To me it seems like you should be able to tune to a non-existent FM station or blank aux channel and "hear" what the ANC is doing. Turn the volume up and see if the effect changes. I would think ANC would be "on" as long as the audio system is on, whether music is playing or not.
Old 05-09-2016, 10:46 AM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Not noticeably diff, sub sounds a bit more muted. I reconnected it....
Old 05-12-2016, 08:00 AM   #12
JoeAyalaM
Drives: Audi S6 V8TT, Volvos XC60 & S60R
Leave the Bose amp alone, use a JL Audio line converter and channel summing (something like this http://intl.jlaudio.com/product/5421.../OEM_Interface ) in order to obtain a good pre Amp signal. There is lots of room in the left side of the trunk for electronics and a nice 10'' sub, without loosing much trunk space.
I hope your build goes well and please post your results.
JoeAyalaM is offline   Reply With Quote
Old 01-10-2017, 12:34 PM   #13
MPScan
Drives: 2017 FIFTY VERT MANUAL 2SS
When you cut the ANC mics, are the phone/bluetooth and car voice command mics different? I think my shop disconnected them all because I lost all voice control in the vehicle.
MPScan is offline   Reply With Quote
Old 01-10-2017, 10:20 PM   #14
JoeAyalaM
Yes, they are different. The door mics are for the ANC only. I had them disconnected inside the door panels, and everything else works just fine.
