Old 04-17-2016, 09:10 PM   #1
Quiksilver16ss
Quiksilver16ss's Avatar
Drives: 2016 camaro 1ss
First oil change
I have 1100 miles now and I'm wondering when the first oil change should take place. I get 2 free maintainance visits with the first 24000 miles. So should I do it at 1500 just to be on be safe side? I read where it didn't come with break in oil from the factory. So I guess it could go longer. And I would think the filter would filter out the metal shavings etc. anyways what have yall been changing yours at??!!!
2016 Camaro 1SS
M6, NPP, MRC, sunroof, black hashmarks, black bowties, Low gloss black 20" wheels
Quiksilver16ss is offline   Reply With Quote
Old 04-17-2016, 09:23 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Get it out now or soon at 1500.......then follow the oil minder or every 5000, or no matter what, every year.
All my opin.....
Old 04-17-2016, 09:39 PM   #3
Quiksilver16ss
Ok I'll call the dealer tomorrow. You think they will give me a hard time about it being early? Seeing it's free for the first two I wouldn't think so
2016 Camaro 1SS
Old 04-17-2016, 09:43 PM   #4
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Dealer should not care, call first.
Old 04-17-2016, 10:00 PM   #5
crabman
Drives: Sniffin the tree.
I would just change the filter. Gives you a look at the oil for unusual conditions (coolant contamination, smell, etc.) and gets you a new filter that isn't clogged with shavings, that fine black stuff from bearings, gasket material, red goo that was put on the gaskets, all that good stuff. You'd be surprised what comes out of a first run oil filter if you open it with a filter cutter and examine it. The oil itself should be fine to go to the first actual service. As said above though this is my opinion.
crabman is offline   Reply With Quote
Old 04-17-2016, 10:32 PM   #6
Quiksilver16ss
True yea the filter probably is full of all that.. Imma get them to just do the full oil change. It's my free oil change and I want it now!
2016 Camaro 1SS
Old 04-18-2016, 07:06 AM   #7
Marine Corps
Drives: 2016 2SS Garnet Red Camaro
There's no way you need to change your oil at 1500 miles! 5000 to 7500 miles. If someone has technical data that supports their opinion about an oil change at 1500 miles please provide. I realize that during the break-in period more crap ends up in your crankcase, but 1500 is too soon. IMO
Ordered: 8/8/15, 2SS Garnet Red
Built: 10/14/15
Current: Took Delivery, 12/24/15
Added Procharger supercharger.
Marine Corps is offline   Reply With Quote
Old 04-18-2016, 12:03 PM   #8
Lancez
Drives: none
I don't have a camaro yet, but if it's synthetic oil, you are basically throwing money away if you change oil at 1500 miles .
Lancez is offline   Reply With Quote
Old 04-18-2016, 12:14 PM   #9
martelds
Go Arizona Cardinals
martelds's Avatar
Drives: 2006 GMC Duramax 2500 HD, 2016 2SS
Funny you mentioned that, I just passed 1500 miles. My gauge cluster is being replaced today. Huge scratches on it. Anyway. They are doing my first oil change today. Only one free change left. I know I don't need to change the oil yet, but I think 50 spent early on the first change is a small price to pay for a little piece of mind. This is my baby and I will treat her better than what the owners manual says.
2015 Nissan Murano SL with Tech Package
2006 Lifted GMC Duramax 2500 HD. Lot's of custom parts!
2016 2SS Garnet Red 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Black Rally Stripes, NAV, Sunroof, Corvette Z51 Black Wheels, Black Front Fascia, aFe / PFADT Suspension Lowering Springs, Black High Rise Rear Spoiler. High flow headers, E85, Roto-Fab Cold Air, MSD Atomic AirForce Intake. aFe / PFADT Front & Rear Sway Bar. Pushing 520 to the Rear Wheels
martelds is offline   Reply With Quote
Old 04-18-2016, 12:14 PM   #10
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
You are only changing oil at 1500 to dump the mfg debris, it has nothing to do with what oil is in the motor. This is one opinion of thought by many, and many others may feel differently. OK with me.
Old 04-18-2016, 12:21 PM   #11
Lancez
Drives: none
Well, in that case you should've changed oil at first 500 mi instead of 1500.
Old 04-18-2016, 12:29 PM   #12
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Quit splitting hairs and playing "gotcha", i did not say i changed at 1500, i changed at 750 when it was convienent for my schedule.
Old 04-18-2016, 12:39 PM   #13
Blazin383
Blazin383's Avatar
Drives: 2016 SS
I'd be a little bit surprised if the dealership will even change the oil at 1500 for free. Typically they won't do that until the diagnostic system in the car tells them its due. The manual says first oil Change at 7500.
The old school of thought about replacing break-in oil in 1000 miles or so has kinda gone away. However, GM has determined that many of the ZO6 Corvette engines that grenaded after only a few hundred miles was because of loose threading fragments from the oil filter threaded fitting that ended up circulating into bearings with the engine oil.
Blazin383 is offline   Reply With Quote
Old 04-18-2016, 12:50 PM   #14
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Gm has said you get 2 free oil changes any time you want, been proven here several times. You decide. Call cust relations if a dealer tells you differently. Alsio you should get mobil 1 free, no upcharge.
