#1 | |
![]() Drives: '16 2SS Join Date: Nov 2009
Preventative Maintenance Upgrades - Magnetic Drain Plugs
So I did a search and didn't see much on this topic except for a mention HERE. I plan to install a few items as soon as I drive the Camaro SS I just ordered home for the break in and onward. I'm going to get a Mishimoto catch can which I won't go into as there is a lot of info on here already.
I will preface these next ones by saying I know nothing is a substitute for frequent oil and filter changes. I had similar types of the following products on my last car and I still think it's good piece of mind for not that much $. 1. I want to get a neodymium magnetic oil drain plug/bolt. I've been told the OEM bolt on the Corvette is M12X1.75X25mm and I assume the Camaro is the same. Is that a safe assumption? I read mention of these on a Corvette forum: PowerSlut Racing (yes that's the real name ) & DIMPLE/Drainplugmagnets.com. The latter people were saying is more expensive but engineered really well. Anyone have experience with these? 2. I also had an oil filter magnet by FilterMag, hopefully the one I had on my 370Z works but I have a feeling the Camaro's will be much larger. Drainplugmagnets.com has their own solution too. They also have some complete kits for some cars and bikes like this one for the Hellcat that covers the trans, diff & engine oil, is there some GM software people have to see what the dimensions of these bolts are on our cars without ordering them or taking them off first?: ![]() If you aren't aware of what are supposed to be the benefits here is what it says on their page:. Quote:
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav 4/06/16 1100 Ordered (waiting for 5ZU acceptance) 4/19/16 2000 Accepted with 5ZU 4/23/16 3000 TPW:5/16/16 5/06/16 3100 5/13/16 3400 Broadcast Sheet 5/24/16 3800 Vehicle Produced 5/25/16 4B00 Bayed 5/27/16 4300 Intermediate Delivery 7/9/16 Delivered! Last edited by G Fo12ce; 03-16-2017 at 05:04 PM. Reason: Updated the post title to be more relevant |
Retired from Car mfrs....
Oil drain bolt is M12 x 1.75 all camaros and vettes
Thanks Glen. It's too bad you aren't near that place.
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav 4/06/16 1100 Ordered (waiting for 5ZU acceptance) 4/19/16 2000 Accepted with 5ZU 4/23/16 3000 TPW:5/16/16 5/06/16 3100 5/13/16 3400 Broadcast Sheet 5/24/16 3800 Vehicle Produced 5/25/16 4B00 Bayed 5/27/16 4300 Intermediate Delivery 7/9/16 Delivered! |
A lotta guys like the filtermags, i just had a stack of mini iridium magnets In the shop that i spread around the filer...About $6 On AMZN.......
#5 | |
I'd like to find out what the bolt sizes are for the 8L90 A8 and diff are. I just noticed in the pic I linked above there's even a bolt for the oil cooler. I wonder if our cars have drain bolts on those?
FilterMAG SS Autos and Light Truck Series Magnets SS300PR fits perfectly on the filter.
Thou i see 2 things that concern me, 1) it gets close to the metal trans line, which i wonder if the magnetic field will cause particles in the trans line to build up and create a blockage over years of driving? 2) Can only stick one on, as little tight between the filter and engine and if you try to put between the filter and engine, could the magnetic field pull metal to build up in that area? |
#7 | ||
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
This magnet will only capture ferrous metals and there are plenty of non ferrous metals in the engine. If you are truly worried about filtering look up "bypass oil filter" thouse will filter down to 1 microns or smaller ![]() This magnet won't hurt anything but it's not very effective, remember all oil that is picked up by the pick up tube is filtered immediately after the pump then to the engine. |
#8 | |
![]() The one I have is FilterMAG RA 250, it fits 2.5 To 2.8 in. diameter filters. What diameter is the Camaro filter? 1: The magnet only pulls one way so if that line is on the back side of the magnet I don't see an issue right? 2: You only need 1 FilterMag. I'm not sure what you mean but it wraps around the filter and keeps the shavings stuck to the filters case. You throw the filter out on an oil change and put the FilterMag back on your new one so the shavings essentially go in the trash.
#9 | |
#10 | |
![]() So was mainly concerned for the magnetic field generating a little pull on the back side near other fluids with metal particles in the trans lines possibly floating in it and the oil within the engine near the filter(if a 2nd magnet was placed on it) I guess it is small chance, but just a concern. You can double up for more coverage of the oil flowing thru on both sides of the filter. About a 3" diameter oil filter case. Here is a pic with the spare magnet(says Filter Size Range: 2.900-3.400 in) and spare filter. ![]()
#11 | |
. Like you said it's probably not a big concern although I don't have the car in front of me like you do. I guess you could run the car for a minute before putting the FilterMag back on if you were really worried to allow fluid to pass through that line and move anything. If you had one for the trans too I guess the hope would be that it would catch any small stuff as well?I also see what you mean about using 2. I had the heavier duty one they offered at the time so I just got the one. It looks like they have newer stuff now. Thanks so much for the measurements HyperBlue, just my luck it looks like I have the one a range smaller so it looks like I need a new one if I decide to get that again. Thanks for the feedback so far.
#12 |
Update: I was able to speak with Richard yesterday, the owner of Drainplugmagnets.com. Seems like a smaller company. I was able to give him a VIN# to see if he can get the ball rolling to see if they have more than just the engine oil plug. We'll see if anything comes of it.
#13 |
Update: I was able to find out yesterday that that the 8L90 A8 is sealed unit and when serviced the fluid is pumped in and out. It has no drain bolt. I am asking here if anyone knows what the pan is made of for sure, although it's most likely steel to so I can go the route of using one on the pan.
The factory drain bolt for the differential is a M20x1.5x16 and already magnetic, although most likely not same pulling power as the Dimple. Dimple makes a M20x1.5x14 (not including the magnet) so they have one that will fit our cars for that. As soon as I find out for sure on the trans oil pan I can tell those interested what would make a Camaro SS "kit" for autos. I'll ask the manufacturer if they will make a package price too.
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav 4/06/16 1100 Ordered (waiting for 5ZU acceptance) 4/19/16 2000 Accepted with 5ZU 4/23/16 3000 TPW:5/16/16 5/06/16 3100 5/13/16 3400 Broadcast Sheet 5/24/16 3800 Vehicle Produced 5/25/16 4B00 Bayed 5/27/16 4300 Intermediate Delivery 7/9/16 Delivered! Last edited by G Fo12ce; 05-11-2016 at 02:48 AM. |
#14 |
This thread hasn't seen much action and I totally get it like I said at the beginning. However, I decided to buy this stuff and be the guinea pig. My plan is to keep this car at least 5 years so if these magnetic plugs and "black holes" help a little bit to improve engine/trans/diff wear great. If not, it's not a huge loss for me. I also wanted to note you can do this a lot cheaper using the PowerSlut Racing fasteners, they also make an M12 and M20. I just wanted to try what I thought was the better product.
I plan to put these on as soon as I get the car. We'll see if I catch anything after break in. When I spoke to Richard at Dimple he said they have a Cerakote coating. It's a titanium dust they use on firearms and other items. I'm sure it's overkill for this application but the titanium grey sure looks cool. It's also supposed to have good chemical resistance, abrasion, and anti-corrosion properties. The magnets are strong and neodymium. There are some video's and other info on their site. Here are some pics I took, sorry a few were out of focus. On the M12 I didn't notice I picked up a staple from somewhere LOL. It was kind of comical trying to keep those black holes apart for the pic. They start to lean and move around even like 3-4 inches away. ALL: ![]() Stack Of 4 Super Black Holes: ![]() M12 Engine Oil Pan Drain Plug: ![]() M20 Differential Drain Plug: ![]()
