![]() Drives: 2013 1Le Join Date: Feb 2014
AFM and aftermarket exhaust
Switching over soon to set of ARH headers and XPipe just got to thinking about AFM on these cars. There is another baffle that closes from my understanding to help with back pressure when it drops to 4cly mode. With the new system that baffle will no longer be in place. Is there potential of running into issues or are people already doing this with zero issues?
![]() ![]() Drives: 2016 Camaro SS Join Date: Jan 2016
You will need to leave the actuators connected or you will throw a code.
So left them just attached under the car I ask because I have yet to get under it on the lift. I assumed they were attached to the exhaust system.
#4 | |
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
So those are your choices, either transfer the valves to the new exhaust, don't replace that section, or go with Stainless Works over ARH. ARH did not bother to build a system compatible with automatic transmission/AFM cars. Neither did kooks
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp Last edited by jimmypop13; 04-14-2016 at 11:42 AM. |
#5 | |
As far as I've been told by the Corvette guys, you can't tune out the AFM electric motor check bc it's not part of the ecm or something like that. I would try searching on the c7 forums to see if things have changed since then.
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
#7 |
![]() Drives: 2016 2SS Red Hot Camaro Coupe Join Date: Mar 2016
Or you could get a range technology plug in to stop the car from going into AFM mode. I bought one but after changing the exhaust, I don't feel I need it.
Proud Owner Of Three Generations Of Camaros. 1968 SS, 1986 Iroc Z and 2016 SS.
#8 | |
And you can not tune out the check engine light for it. You will get a check engine light unless the AFM motors are functioning, no tune will change that. Stainless Works offers a dummy mount for the AFM motors that's just like the real thing but no valve is in the exhaust.
#9 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
#10 |
![]() Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
Seems like the actuators could be replaced with a coil, relay, and resistor to prevent codes from showing up. Then can the actuators. Just thinking out loud.(?)
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS H50 Join Date: Mar 2016
I installed Borlas x-pipe with the afm valves. After a couple tries from Borla, they got it right and the CEL went away.
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
You will have to tune for the headers so you can tune out AFM mode at the same time. That will prevent the engine from running in V4 mode but that won't prevent the CEL for disconnecting the AFM acutator.
I believe HP Tuners has a way to tune out the AFM valve check but it is in the body control module (BCM) and not the ECM or TCM. It costs more points to tune that module. I believe many people use the method below. The AFM exhaust valve is two pieces. The actuator motor connects to the wire harness and is bolted to the actual valve in the exhaust. You can unbolt the actuator and leave it connected to the wire harness to eliminate the CEL while removing the AFM exhaust valve. Just carefully tie the actuator up to the bottom of the car someplace where it won't be damaged. |
#13 |
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
You just need the actuators leaved them plugged in and zip tie them. It will be ok no cel
Ported intake manifold and throttle body kooks 2" headers no cats
#14 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
You absolutely can tune out the AFM modules and not throw a code. It's in the FPCM and requires an extra credit with HP Tuners.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
