Old 04-12-2016, 06:09 PM   #1
AndOne707
Drives: 350
Coilovers options for the SS 16 ?
Do we have any coilovers options at this point that the car can benefit from ?
And also how would this compare to the MRC from the dealer ?
Thinking of ohlins or KW but haven't found much info
Any recommendations for those who track their SS ?
And one Last question. What was use in the 5th z28 set up ?
AndOne707 is offline   Reply With Quote
Old 04-12-2016, 06:51 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
Afe power aka pfadt is using my car to make a set for non mrc equipped vehicles!
Old 05-21-2016, 10:47 PM   #3
diirk
diirk's Avatar
Drives: 2016 Camaro SS
There should be a few other options eventually.
BC
H&R
Eibach
Bilstein
ST
diirk is offline   Reply With Quote
Old 05-22-2016, 08:09 AM   #4
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
BC
H&R
Eibach
Bilstein
ST
hopefully ridetech as well...
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 05-23-2016, 07:21 PM   #5
doc212121
Drives: 2016 Camaro 2SS White/White
BC will have their first set to me in a couple weeks
doc212121 is offline   Reply With Quote
Old 07-13-2016, 09:17 PM   #6
Rich J
Drives: 2018 ZL1 Manual
Any updates on coilover options?
Rich J is offline   Reply With Quote
Old 07-13-2016, 11:27 PM   #7
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Detroit Speed?
http://www.camaro6.com/forums/showpo...15&postcount=1
LibertyHill is offline   Reply With Quote
Old 09-15-2016, 02:52 PM   #8
diirk
diirk's Avatar
Coilovers from BC are now available. You can get the standard OTS BC BR for under $1k. You can get them with Swift springs for a few hundred dollars more including custom valving for the springs.
I personally deal with Andrew at http://www.openroadtuning.com. He's already talked to BC and confirmed availability. If you go with the Swift springs and custom valving, expect a 2-3 week delay. 1-844-620-2708
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
Old 09-15-2016, 05:48 PM   #9
mild2wild
Drives: 2017 1LE
Have you had previous experience with BCs? I have a set with the Swift springs on a different platform, and it rides terribly; much too stiff, and the spring rates are lower than what they supply on their standard setup. Maybe you've experienced something different, though... I just could not recommend the brand without first riding in a Camaro equipped with them.
mild2wild is offline   Reply With Quote
Old 09-15-2016, 06:16 PM   #10
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Swift springs are a track spring. I wouldn't want them in my Daily Driver
Old 09-15-2016, 09:26 PM   #11
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
Hmm might pick these up in the springtime. By then there should also be some other options.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 09-16-2016, 08:56 AM   #12
diirk
diirk's Avatar
I have and didn't have an issue. I have another set on order for a different platform which should arrive next week. I'll give a review of those when they arrive. The valving should match the spring rates and the rates when using Swift springs are custom, chosen by the customer usually. So it's possible that something became confused when ordering.
1morproject
Old 09-16-2016, 08:57 AM   #13
diirk
diirk's Avatar
That's an incorrect statement. Swift springs can be used on a track. It;'s just a spring. But one that is made well with rates that are spec'd much closer and accurately then most OEM springs. Just mfg'd to better tolerances.
The spring rate is the rate, whatever you spec it out too.
1morproject
Old 10-05-2016, 08:47 AM   #14
diirk
diirk's Avatar
OK, just thought I'd update a little. I had mentioned that I had some BC's on order for another platform (I haven't got around to ordering for the Camaro yet). They are installed and awesome. Ride quality is excellent. Rides like stock driving down the street with less body roll. There is absolutely nothing I can complain about, more importantly, my wife is happy (it's her car). And yes, BC Customs with Swift springs and custom valving to match the springs.
Really looking forward to getting them on the Camaro.
1morproject
