Old 04-06-2016, 09:08 PM   #1
hbladuell
Drives: 2016 Camaro LT2 RS V6
V6 top speed
I am in the research stage for buying a gen 6 V6 Camaro. I have searched the web but I canīt find the governor top speed. Every road test a have encountered talks about estimated top speed. What is the V6 top speed? Has someone driven the car to its top speed?
hbladuell is offline   Reply With Quote
Old 04-06-2016, 10:06 PM   #2
KMPrenger
KMPrenger's Avatar
Its likely based on the tires, so the RS models may have a higher top end, but maybe not since I think all the 6th gen V6 tires are high performance all seasons.
On my prior 5th gen V6, the RS had the summer performance tires, and the top speed was higher than non RS cars. Top speed was 155
Old 04-07-2016, 05:47 AM   #3
hbladuell
Thanks for the response. The GM site only mentions 245/50R18, blackwall, all-season tires (regular package) and 245/40R20, blackwall, all-season, run-flat tires (RS package). There is no high performance rating.
Old 04-07-2016, 09:47 AM   #4
tchowe
Drives: 2017 V6 Camaro RS
I believe RS top speed is 155. I read about a 2016 v6 RS dyno run and they mentioned they hit the 155 limit.
tchowe is offline   Reply With Quote
Old 04-07-2016, 02:22 PM   #5
Goobaba
Drives: 2016 V6 RS Manual
Yeah the phastek dyno run got cut short by a 155 mph gov limited top speed
Goobaba is offline   Reply With Quote
Old 05-13-2016, 06:38 AM   #6
hbladuell
What about the non RS V6? What speed rating does the tires have? What about the speed governor limit?
Old 05-13-2016, 08:45 AM   #7
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
Both RS & non RS are limited to 155 IIRC
keysersoze is offline   Reply With Quote
Old 07-22-2016, 12:13 AM   #8
tmannband
Drives: 2016 Camaro 1LT V6 6 spd
No doubt it will exceed 155
Just did a quick 4 day trip, Florida, NY and back to Florida. I would normally fly up but my new 2016 plain Jane white V6 speed overruled me.
Chevy's speedo is right on the money as checked against my GPS. At 3am with tail lights in the distance I had to try it. Probably should have checked the break in rules. It had 340 miles when I left FL.
I-95 South, cool night and hopefully clear of the Bulls I shifted to 3rd and hit it. I saw 146mph in 5th and it was still pulling strong. I have no doubt this little car would break through the 155 barrier.
I have not owned an American vehicle except for trucks since the 70's. I'm so glad I bought this little gem when I did.
Driver age: 69, still a kid
tmannband is offline   Reply With Quote
Old 07-22-2016, 09:05 AM   #9
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
I'd never hit that in the big city, it's a challenge to hit 75 around here, always someone needs to get in your lane right in front of you....At the track, straights only allow you at least 125, depending on the track. Interstate, DPS troopers everywhere. 80 is a challenge. Oh I hit 100-115 at times...but the fun is very short...
top speed on these is limited to 155 as mentioned above. Again you will never see it.
12blkgrayRS is offline   Reply With Quote
Old 07-22-2016, 09:07 AM   #10
MovieGuy
MovieGuy's Avatar
I am 60 and I don't wanna grow up! Having a car like this helps keep me young
http://www.camaro6.com/forums/image.php?u=115947&type=sigpic&dateline=1461721697
Life after retirement
MovieGuy is offline   Reply With Quote
Old 07-22-2016, 11:34 AM   #11
Allez
Allez's Avatar
FWIW the 2016 Camaro brochure lists the top speed of both the turbo 4 and V6 as 149, v8 as 180.
Allez is offline   Reply With Quote
Old 07-24-2016, 12:25 AM   #12
KirkH
Im surprised at how quickly this car goes from 70 mph to 100 mph. I havent timed it yet but cruising at 70 and then mashing it, I get to 105 really quickly!
Old 10-08-2016, 09:30 AM   #13
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
My 2014 V6 topped out.
BSR-1 is offline   Reply With Quote
Old 10-09-2016, 05:06 PM   #14
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
no clue where you were, don't need to know, but impressive. most will never have the confidence to get that high, even on a test track.
last time I saw numbers there, I was a passenger in my cousin Markus's brabus modded setup on the autobahn at 16.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
