![]() Drives: 2016 Camaro 2SS Join Date: Jan 2016
Cat Delete....
Has anyone removed the cats from there? You know, "for track only" reasons? If so, did any codes pop up? Run into any issues? I was considering buying the delete kit. But not ready for all the dummy O2 sensors, blah blah crap. Any comments, concerns, etc... are welcome...
![]() ![]() Drives: 2016 Camaro SS Join Date: Jan 2016
You will get codes. You either need to tune out the rear sensors or install O2 simulators.
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Are talking about the primary cats or the secondary un-monitored cats? For primary cats, you will need some extra stuff for. For secondary un-monitored cats, don't need anything. Before someone says the secondary cats are resonators, they are not. They are cats.
If we are talking about Primary cats, TSloper is correct! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Car Join Date: Jun 2010
I deleted a couple cats by getting a dog.
![]() Drives: 2016 2SS Black/Black Join Date: Apr 2016
So has anyone deleted them yet or not?
Bad drone inside? Much louder outside? |
![]() Drives: 16 Camaro SS Join Date: Nov 2015
#7 |
I ordered mine on Monday. I'll be installing them as soon as they arrive.
#8 |
![]() Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
so whats the pros/cons for deleting the primary cats only vs deleting the secondary cats only?
can the secondary cats handle not having the primary cat ahead of it? Is one more restrictive then the other? |
#10 |
![]() Drives: White 2016 Camaro SS 1ss A/8 MR NPP Join Date: Mar 2016
The secondary cats have no sensors or monitoring after them ...so removing them won't trigger any engine lights or negatively affect performance. if you remove the primary cats you will have to do some mods to have the car run right...and even then it won't pass any state emissions inspection
#11 | |
The Dogfather
Also, removing primary cats = warranty issues as you have to "mess" with the ECU which GM doesn't like and could easily be an issue. Both the secondary and primary cats are very restrictive. If you don't want to deal with warranty issues, you can just get rid of the secondary cats as they are un-monitored and don't have to get a tune. |
#12 |
So is there a bolt on piece for the secondary cats?
Or are y'all having a muffler shop weld in pipe? |
#13 |
The Dogfather
For primary cats there is a vendor here who make cat delete bolt on pipes. As for the secondary cats you have to get em cut and replaced with straight pipes then welded (NPP is 1 pipe from the primary cats and the secondary cats are on that 1 piece so you gotta cut and weld :/). I am not a huge fan of mine as they are 2.5' and not 2.75' BUT I knew that to begin with and did it as a temporary solution till Borla releases their off road xpipe. Till Borla xpipe happens, I am uber happy with the extra sound under throttle and LOVE the back pressure
#14 |
Could a person potentially "Gut" the secondary cats, that way they are still on there and not void the warranty?
