Old 04-05-2016, 11:33 AM   #1
Welcamaro16
Drives: 2016 Camaro nightfall gray 6spd
Drag radial help
Went to the track with my stock tires and the m6 and it was like it was on ice! Anyone know of a good drag radial set up that will fit on the 2016 Camaro 2ss? Just curious what everyone is running. I have no idea where to start on trying to pick a size wheel or tire any help would be appreciated thanks!
Welcamaro16 is offline   Reply With Quote
Old 04-05-2016, 12:03 PM   #2
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
what tire size are u running in the rear now. you could either go with MT or nitto.
R3DLT1 is offline   Reply With Quote
Old 04-05-2016, 12:24 PM   #3
HumanWiki
Drives: Car
Stock rears are 275/35/ZR20
HumanWiki is offline   Reply With Quote
Old 04-05-2016, 12:26 PM   #4
HumanWiki
Drives: Car
Check in this thread or PM atomicfusion
http://www.camaro6.com/forums/showthread.php?t=442347
Old 04-05-2016, 01:38 PM   #5
big hammer
Drives: 2002 ws6
Nittos aren't a good tire for a manual. You need something with a softer side wall like a hoosier
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
big hammer is offline   Reply With Quote
Old 04-05-2016, 02:14 PM   #6
Snowblind
Snowblind's Avatar
I had an extra set of wheels so is went this route. I have M/T 305/35/20 mounted on a widened factory wheel ( I like the stealth look ) and I switch them out for daily driving. If you keep your 9.5 wheel then I think your only MT option is a 275 tire. As was previously mentioned, with your M6 you want the tallest sidewall you can find.
Old 04-05-2016, 04:34 PM   #7
laynlo15
Drives: 2022 Lt1 A10
I think it will really help the M6 more then the A8 although sometime this year I'll probably get a set and they will be M/T's.
Old 04-06-2016, 08:20 AM   #8
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
i use to daily drive nittos 555r on my 95 camaro 305/35/18 they hooked on the streets just fine.
