Old 04-01-2016, 10:22 AM   #1
ender2664
Drives: 2016 2SS
Competition mode
When at a stop do I have to floor it all the way to get it to work?or can I Rev it to 4k and drop from there?
ender2664 is offline   Reply With Quote
Old 04-01-2016, 10:29 AM   #2
HumanWiki
Drives: Car
I think you're referring to Launch Control, not Competition Mode.
Comp Mode is entered while in Sport or Track by pressing the TCS button twice. Launch Control is then available to you by holding the clutch in, car in 1st gear and rapid full accelerator application. When you release the clutch, LC will handle your acceleration through 1st gear.
Page 224-225
https://my.chevrolet.com/content/dam...ro1stPrint.pdf
HumanWiki is offline   Reply With Quote
Old 04-01-2016, 10:30 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Amazing how that manual works......
Old 04-01-2016, 10:50 AM   #4
ender2664
Drives: 2016 2SS
I've read the manual and it states to put the accelerator to the floor but I didn't know if it kicked in based in wheel spin and thus didn't have to put it down all the way.
Old 04-01-2016, 10:53 AM   #5
HumanWiki
Drives: Car
It's operated as stated in the manual, it will control wheel spin for you on launch not based on pedal input from launch. It's supposed to allow for an optimal amount of spin (note, not 0 spin) to get you moving, but not so much that you lose time or control. I can't tell you how/where it holds RPM on Gen6, but in Gen5, you'd notice it in operation because the RPMs would hold below redline even when floored.
Old 04-01-2016, 10:54 AM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Nope, gas pedal to the floor, every time you use launch control (which only active in competition mode). The computer will hold rpms where they need to be...then you quickly let out the clutch (don't dump it), while continuing to hold the accelerator to the floor.
Old 04-01-2016, 11:19 AM   #7
6spdhyperblue
Drives: 2SS 1LE
honestly i think LC revs too high for stock tires. i think mid 2k rpm, little slip with clutch, and then hit it and let the torque pull you out. i havent been to the track yet tho. i want to play with my 60' soon
Old 04-01-2016, 12:30 PM   #8
ender2664
Drives: 2016 2SS
First- thank you for the answers
second- anyone use this on the street?
third- im still braking in the car, I assume the car tells you when LC is on? Id hate to attempt to use it and just launch a smokey burn out because it wasn't engaged.
Old 04-01-2016, 12:58 PM   #9
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
You should notice that it holds the revs at the correct RPM. If it wasnt engaged you would just be hitting the limiter. (Based on my experience in a C7, Have not attempted in a manual Camaro yet.)
Lucely Engineered is offline   Reply With Quote
Old 04-01-2016, 02:14 PM   #10
Mr. Wyndham
^ This. There is no message "Launch control on"...it'll hold the revs at a specific spot without hitting the redline when you mash the throttle.
Old 04-01-2016, 05:17 PM   #11
ender2664
Drives: 2016 2SS
What rpm does it hold at?
Old 04-01-2016, 05:21 PM   #12
Mr. Wyndham
It's a smart launch control function, so the computer uses temperature, barometer, oil temp, etc, etc, etc to determine the best rpm level to hold. So it varies. It usually hovers somewhere in the range of 4000 rpms.
Old 04-01-2016, 09:04 PM   #13
ender2664
Drives: 2016 2SS
Thank you.
I thought the manual said to dump the clutch. Is that not the case?
Old 04-01-2016, 11:31 PM   #14
Danew_377
Chief Bief
Danew_377's Avatar
Drives: Nightfall Gray Camaro 1SS
I actually did this with a friend in my car a few hours ago. Clutch all the way down when in track mode and competition mode acknowledged by the car. Gas pedal all the way down. My car held steady at about 4800, and I let the clutch out quickly. Maybe too quick. Car still peeled out with noticeable but not uncontrollable wheel spin. Stayed fairly straight.
Danew_377 is offline   Reply With Quote
