6th Gen Steering wheel in 5th Gen?
Anyone know if a 6th Gen Steering Wheel can be swapped into 5th Gen? or a C7 Steering wheel as I hear its the same...
Thanks :-) Last edited by FastGirl; 05-09-2017 at 12:48 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GMC Sierra AT4 Join Date: Jul 2013
It would depend on whether the column is different, using different wiring harness connectors and the keyed mount in the center. You would literally have to see a 16 Steering wheel without the airbag and compare it to the style that is in yours.
One note on the 16 steering wheel, I noticed GM borrowed the Camaro logo & chrome trim from the 2010-2011 Steering wheel.
2020 GMC Sierra AT4 6.2L
WTB - 2010 Camaro 1SS or 2SS, Aqua Blue Metallic, A6 |
#3 | |
And it look so much better. |
![]() Drives: 2015 Manual Hot Red 2LS Camaro Join Date: May 2015
Waiting for a guinea pig...
I kinda like it (which is about one of the only good things about the 6th gens I like, I think the car is just fugly!!).. That and moving the door handle was the only good thing. And the trunk having more space is nice, otherwise ewww!! ![]()
![]() ![]() ![]() ![]() Drives: C6 Corvette Join Date: Sep 2013
I was literally thinking about this same thing myself today. problem is finding one to even try it with
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
![]() Drives: '11 SGM 1LT/RS, '02 SOM Firehawk Join Date: Jan 2014
More importantly, can a 6th gen HEATED steering wheel be swapped onto a 5th gen?
Yippee38
#7 |
![]() ![]() ![]() ![]() Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
I'm willing to buy a 6th gen steering wheel If someone can make it work. Probably need the clock spring too but I am very interested in the swap. I want to put a 6th gen heated in My 5th gen bad.
http://www.trunkmonkeyparts.com/oe-gm/23379912 Last edited by Rainbow1616; 06-28-2016 at 05:53 AM. |
#8 |
My guess is that the steering wheel that you have linked does not include the airbag. The airbag is usually pricey......
2010 Black Camaro 2SS
#9 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
#10 |
#11 |
Airbag probably would run $350-$500 depending on who you buy it from
#12 |
![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
Seems like the 6th gen steering wheel has a few more functions than the 5th gen. Electrically, that my be a bigger hurdle than physically mounting the wheel.
#13 |
I finally was able to compare the wheels in real life. They have the same number of button functions (except for the heated wheel of course).
I am about to order the wheel, air bag, and coil and give this a shot. Everything I read says the bcm does Not have to be reprogrammed. Therefore I am fairly confident I can make it work. I will report back here when completed. |
#14 |
Instagram: Sangstah
Not a fan of the bulky 6th gen steering wheel, it was one of the first things I spotted in the interior and it threw me off.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
