03-22-2016, 07:43 PM | #1 |
Nightfall Gray Blackout
Drives: 2016 Camaro 2SS Join Date: May 2012
Oil change
Anybody change the oil yet?
Where is the filter an where do you pt the jack? |
03-22-2016, 07:46 PM | #2 | |
Drives: 2016 Camaro SS Join Date: Jan 2016
03-28-2016, 08:43 AM | #3 |
OspreyTech
Drives: 2016 Camaro 2SS Join Date: Mar 2016
That didn't really answer the questions.
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
03-28-2016, 09:35 AM | #4 |
I can't find it again but I saw a post that showed the filter and it is right next to the oil drain and easy to find and see. Its mounted straight up from the bottom with the bottom of the filter almost even with the oil pan.
I suggest ramps for the oil change, the drain in in the rear of the oil pan so having the front end up will aid in draining the oil. |
03-28-2016, 12:56 PM | #5 |
Read the owner's manual for the jack points. You will see why you want what I suggested.
As for oil filter location... look underneath. |
03-28-2016, 01:04 PM | #6 | |
Drives: 2017 2SS Join Date: Jun 2014
Not jacking on a pinch weld. |
03-28-2016, 01:11 PM | #7 |
That's exactly where you should be jacking.
