Old 03-21-2016, 09:22 PM   #1
speedxxx3
Drives: camaro ss2016 white
Glitches with my clutch
My 2016 camaro ss has an issue with a high clutch I am wondering if this is normal for all ss. I brought it to my dealer to diagnosed this issue and they ruled out any problems with the clutch and that they cant regulate the clutch because its hydraulic.
Can anyone tell me if this is normal for an ss or not?
speedxxx3 is offline   Reply With Quote
Old 03-21-2016, 09:35 PM   #2
speedxxx3
Size:  206.6 KBthis regulator is used to regulate the clutch or not? can anyone help me with this ???
Old 03-22-2016, 12:23 AM   #3
Richie Carbone
Richie Carbone's Avatar
Drives: My work van for now
How many miles on the car?
Richie Carbone is offline   Reply With Quote
Old 03-22-2016, 01:18 AM   #4
speedxxx3
1200 milles
Old 03-22-2016, 10:37 AM   #5
Richie Carbone
Give it time to wear in. The pedal will come down a little bit when that happens.
It's normal. Put some more miles on it and run it through the gears.
Old 03-22-2016, 12:52 PM   #6
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Honestly I do not see a problem with the clutch disengaging higher in the pedal travel. It is is when you are almost at the floor board and it disengages would be an issue for me.
I have to say the clutch in my car seems to have moved the engagement just a little down and I have about 4300 miles now.
drivingagain is offline   Reply With Quote
Old 04-25-2016, 02:27 PM   #7
raptor5244
Drives: 2022 CT4-V Blackwing
All the Tremec manual transmissions I have owned have clutches with a high engagement point, I have had 2 corvettes and now a 2013 Camaro SS 1LE. I personally don't like it but I have just gotten used to it. The engagement happens at a very specific point, which is why some folks don't like it. You have what feels like an inch of travel between engagement and disengagement of the clutch, which is why it can be harder to drive smoothly. You have to provide the right amount of "finesse" through that engagement point and the smoothness will vary based on RPM, etc.
Most of the Japanese cars I have driven have a larger range of clutch engagement and start to bite around 1/2 way instead of 3/4, which I find a little smoother to drive. Either way, you just get used to it over time.
Old 05-20-2016, 07:13 PM   #8
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Hydraulic clutches are not adjustable that way. If it doesn't slip its normal.
I personally hated the clutch in mine and I worked out a deal with CenterForce to develop a new twin for the 6th Gen. Love my new clutch and its starts to grab a lot lower than the stock clutch.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
