![]() Drives: 2015 STI Join Date: Feb 2016
Tire Options
Has anyone tried to find a set of tire for the 1LE. There are not may choices. I think tire rack lists 2. I've even checked a few manufacturers sites. A lot make some for the front OR rear, but not both. Does anyone have any ideas on where to find more options?
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
285/30-20 there are 24 tires
305/30-20 21 tires Pilot Super Sports are made for front and rear. Not sure where you are looking? |
Individually, yes there are that many options. There are not that many that match.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Match what?
Front and rear.
Tire rack does list several options but of those there are only 2 match front to rear. If you look by size and choose the staggered fitment, only 2 options show up. I have found those 2, plus the stock and maybe 1 or two others by searching manufacturers sites. |
#6 | |
#7 |
Correct. I'm just looking for a few more options for a staggered set up for a 6th gen 1LE where the front tires are the same type and compound as the rear. It seems there are only a few because of the sizes.
#8 |
The goodyear tires do not exist yet either but they are coming with the 1LE and ZL1, so id bet we see some tire choices open up once the car gets released. Also there is a possibility of plus sizing to a more common tire size but seeing that these are 20s.. hah who knows.
#9 | |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
Problem is that 20" high tires are fairly new. It takes a while for companies to catch up to demand. Not much in the way for wide 19s either... it takes time. I still remember when 17s were "tall" for a wheel. Now, they're VERY common, practically the normal size for a wheel dia. --kC |
#10 |
I hope you're right. I'm really looking forward to the car. It would be nice to have a few more options. I've heard good things about the goodyears that will be on it, but sometimes aftermarket does better and or cheaper.
#11 |
#12 | |
--kC |
#13 |
I was hoping to see both of those, myself. Yokohama doesn't have a single tire that'll work with the stock 1LE wheels, yet. But I really like the RE71s I'm running on my Subaru.
#14 |
![]() Drives: 2004 Z06 Join Date: Jan 2016
No plans as far as I know for 20in in those options. Bridgestone has the 285 in 19in and are planning on releasing a 305 in 19 as well. Rival has nothing larger than 18in planned...
