![]() Drives: 2016 1SS Join Date: Feb 2016
BMW Staggered Rims
Traded my BMW 335i for the new Camaro.
Decided to test fitting my 18” BMW rims on the Camaro for a future winter setup. Actually calling for snow this week here so may have to get new rubber. Rim Specs: Front: 18”, Width=8.5, Offset=34 Rear: 18”, Width=9.5, Offset=34 Lots of clearance more than finger all around. Front struts clear. Was surprised how little clearance the stock tires have from the rubber to the lower strut spring perch. Have to make sure not to go to larger overall diameter for winter setup. Hope this helps. Please keep in mind the overall tire diameter (rubber) is way small by few inches. |
Forgot to mention that the hub bore diameter is larger in the BMW rims.
FMPG
Drives: 2016 2SS Join Date: Dec 2015
Thanks, that's interesting. Can you post some profile shots of it on the ground so we can see what the wheel gap looks like?
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge ![]() 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
If it's for snow tires, I would think function>form.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#5 | |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Also Im not sure what lugs you are using I am assuming the Camaros but you need to ensure the seat angle is the same for the wheel and the lug nuts. |
#6 | |
Overall diameter is like 4 inches smaller so ride height would be like 2 inches lower to the ground. Also weight of the stock Camaro wheels and tires was surprisingly heavy guessing around 70 lbs. My 18's feel like feather weight in comparison like 40 lbs. Once I put in the correct tires like 245/60/R18 it will weight more but I'm also guessing less than 20's. |
#7 | |
