Old 03-19-2016, 11:31 PM   #1
oldman
Drives: SS 6 speed of course
SS 8.6 diff grears and LSD?
I'm starting my build and I've tossing around the idea of 4.10s. Is this the same diff as the gen 5? It is the same size ring. I've also heard stories of a relatively weak posi. Might look into changing that at the same time. Do any forum vendors know???
Old 04-18-2016, 11:28 AM   #2
GreaseMonkey83
GreaseMonkey83's Avatar
Drives: 2016 Camaro
+1. I'd like to swap the factory 3.73's for the 5th gen 1LE gears if possible.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it
GreaseMonkey83 is offline   Reply With Quote
Old 04-18-2016, 11:51 AM   #3
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
The 5th gen 1LE had 3:73's...
Old 04-18-2016, 02:03 PM   #4
GreaseMonkey83
Drives: 2016 Camaro
http://www.camaro5.com/forums/showthread.php?t=298521
Old 04-18-2016, 03:30 PM   #5
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Yeah, duh, I was thinking about how the transmission gearing is now the same. A 3:73 to 3:91 swap wouldn't even be worth the time though. If I was going to go through all that I would do 4:10's...
Old 04-20-2016, 10:55 AM   #6
oldman
Richmond gear says their 4.10 should fit and wanted to verify the center carrier part number. Does anybody have access to the 2016 part number? It is easy to get 2015 and below part numbers. 2015 Carrier: 22928327 manual and 2292836 for auto
Old 06-07-2016, 12:59 PM   #7
stars_fan
Nerd
stars_fan's Avatar
Drives: 2016 Hyper Blue 2SS
Did you ever figure out if the 5th and 6th gens can swap gears?
Hyper Blue 2SS, 6M, MRC, NPP & Sunroof
stars_fan is offline   Reply With Quote
