Old 03-12-2016, 03:19 PM   #1
bseiter98
Memory seats & mirrors
Anyone have any problems with the memory function? I programmed it in location 1 and it worked for a short time but then quit. Thanks!
bseiter98 is offline   Reply With Quote
Old 03-12-2016, 03:26 PM   #2
tecboy
tecboy's Avatar
Accidentally switch remotes?
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 03-12-2016, 03:41 PM   #3
bseiter98
Nope... Also been having issue with the engine sound management (selecting sound via default or by tour, track, sport, etc.) not showing up as a display option.
Old 03-12-2016, 04:22 PM   #4
1badrwd
1badrwd's Avatar
Drives: 2016 camaro 2ss npp, A8
Are the memory buttons tied to each remote? haven't came across this yet but good to know it that's the case.
1badrwd is offline   Reply With Quote
Old 03-12-2016, 04:23 PM   #5
1badrwd
1badrwd's Avatar
is the car running while your trying to do this? don't believe you can change it without it running.
Old 03-12-2016, 07:39 PM   #6
grnflash
grnflash's Avatar
Drives: Hard
Yes. I found this out the hard way after switching the automatic seat return on in the settings menu, and grabbing the wrong key (remote) on the way to work the next morning... I thought I had pissed-off Bumble Bee for a second!
grnflash is offline   Reply With Quote
Old 03-26-2016, 09:07 AM   #7
CamaroNight
Drives: Black 2016 Camaro 2SS 6spd
I can only get my easy exit settings to work. I have to manually hold the 1 button every time I get in the car. I've the settings with the car on both keys and no matter what I do the auto memory recall doesn't work. I even watched that C7 video of the same issue as its my understanding it is the same system. Is this feature not offered in a manual or perhaps I need a trip to the dealership? Any ideas would greatly be appreciated.
CamaroNight is offline   Reply With Quote
Old 06-29-2016, 12:17 PM   #8
Sooks569
How do you activate the auto memory recall? I have the position set via the door buttons and enabled the option in the preference settings, but nothing happens when I turn the ignition on. I also have the easy exit enabled (since I'm a bigger guy it makes it a little easier to get in and out). I keep reading something about programming the remote to make the auto recall work, but how do I do that????
Sooks569 is offline   Reply With Quote
Old 06-29-2016, 12:50 PM   #9
gunny27
gunny27's Avatar
Check out page 56 of the manual.
gunny27 is offline   Reply With Quote
Old 06-29-2016, 12:51 PM   #10
gunny27
gunny27's Avatar
If equipped, the 1, 2 SET, and
B
(Exit) buttons on the driver door are
used to manually store and recall
memory settings for the driver seat
and outside mirrors.
Storing Memory Positions
To store positions to the 1 and 2
buttons:
1. Place the ignition in ON/RUN/
START or ACC/ACCESSORY.
2. Adjust the driver seat and the
outside mirrors on some
vehicles to the desired driving
or exit position.
3. Press and release SET. A beep
will sound.
4. Immediately press and hold 1
until two beeps sound.
5. Repeat Steps 1
4 for a second
driver using 2.
B(Exit)
button and easy exit features,
repeat Steps 1
4 usingBto store
your position for getting out of the
vehicle.
Manually Recalling Memory
Positions
Press and hold 1, 2, or
Bto
manually recall the previously
stored memory positions. Releasing
1, 2, or
Bbefore the stored
positions are reached stops the
recall.
Automatically Recalling Memory
Positions (Auto Memory Recall)
If programmed on in the vehicle
personalization Menu, the Auto
(Automatic) Memory Recall feature
automatically recalls the current
driver
s previously stored 1 or 2
position when the ignition is
changed from OFF to ON/RUN/
See
Auto Memory Recallunder
Comfort and Conveniencein
Vehicle Personalization
0 140.
To stop recall movement, press one
of the memory, power mirror,
or power seat controls.
RKE transmitters are not labeled
with a number. If your memory seat
position is stored to 1 or 2, but this
position is not automatically
recalling, then store your positions
to the other button or switch RKE
transmitters with the other driver.
If the vehicle
s driver has changed,
in some vehicles the Driver ID may
be displayed for the first few ignition
cycles.
Easy Exit Recall
Easy exit recall automatically
activates when one of the following
occurs:
The vehicle is turned off and the
driver door is opened within a
short time.
The vehicle is turned off with the
driver door open.
of the memory, driver seat,
or outside mirror controls.
Old 06-29-2016, 02:40 PM   #11
Sooks569
I read it, it still doesn't tell me how to get it to function. It's enabled on the menu (and there is no sub menu, so no additional options are available). How do I attach the memory setting on the door to a particular fob when I start the car?????
Old 06-29-2016, 05:15 PM   #12
Bad Rap
Bad Rap's Avatar
Drives: 2016 2SS Vert. 2012 Ford Raptor
I've gotten so pissed off trying to get these settings to program. The latest thing I'm trying is to set them AGAIN...then use the fob I want programed and lock and unlock the car. Seams to be working so far, time will tell!
Silver 2SS Vert, A8, NPP, MRC, Black Wheels, Black Rally Strips.
Bad Rap is offline   Reply With Quote
Old 06-29-2016, 05:35 PM   #13
Sooks569
Ok, so it's set on the door. So, does that mean every time I lock and unlock the door I have to use the key fob to get the car to recognize it. No more using the button on the handle???
Old 06-29-2016, 07:50 PM   #14
Bad Rap
Bad Rap's Avatar
It should remember the settings for each of the fobs.
