PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Minor Paint Issue on Laser Weld (Roof)
Hey guys, I've had my car for about a week, just noticed this minor paint defect in the laser weld section of the roof. It looks like the paint bubbled then GM or someone tried poking it to make it go away. Pardon the dirty car.
![]() Does anyone know what will need to be done to correct the paint defect? Hmm I wonder if it's craters or air entrapment like outlined here? Or could it be solvent pop? http://www.paintforcars.com/blog/com...pening-part-1/
![]() Last edited by SPARTAN sui; 03-11-2016 at 05:21 PM. |
![]() ![]() ![]() Drives: 2011 Black SS M6 Join Date: Oct 2010
Grind, sand, prime, sand some more and then paint.
PC Technician
Any idea how big of an area of paint they would need remove to correct this defect? I'm most concerned about quality of work. This is a tiny defect, I don't want to have the work performed by a shop that's going to make it look worse. Also being metallic paint I have concerns about blending.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
The issue is it looks like the metal is exposed so it will start to rust so you have to do something on it.
PC Technician
Yeah I'll be taking it in to the dealership after the weekend to get a body shop lined up to fix it. I'm washing it tomorrow, hopefully it's the only defect I find.
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
I'd leave it alone unless part of the panel underneath is exposed. Don't you normally have to repaint the whole panel with metallic paint? This would be a large area since it wraps around right? And I would never go with a dealer paint shop at least not in my experience. There's only one, maybe two shops, in all of Houston that I think I'd let touch my car's paint. I just don't think it'd be worth the trouble unless there really is an exposed portion that paint isn't covering
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
#7 |
Don't touch it, the dealer should have noticed that before delivery. That's more then a minor issue since they'll have to paint the complete roof, can't blend that.
#8 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
Bring it back and raise hell.
#9 | |
LT-Won!
Drives: USB ISF 5.0 Join Date: Mar 2016
I'd hate for them to fix a problem and create a couple new things like say a run, bubble, haze, swirl or some other artifact. Best of luck op on what you decide. |
#10 |
PC Technician
Under closer inspection it looks like the issue is in the clear. I do not not want my entire roof repainted for the reasons stated.
The dealer is 7 hours away, can't really raise hell.
#11 |
![]() ![]() Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Since it looks small and you only just found it get some dr.colorchip or similar and reduce the issue to where you can't see it.
Your car will get chips and what not when driving so it may of happened from something hitting it when driving. Either Way since you said you are far from the dealer and do not want the whole roof repainted id just touch it up. |
#12 |
PC Technician
Yeah I'm thinking I want to go the touch up route. However I'm going to get in touch with the local dealer and see if the local body shop could touch it up. They're going to be more skilled than I am.
#13 | |
![]() Drives: '69 Camaro SS/RS Join Date: Oct 2013
I followed this guy's advice when touching up a chip in my '69 camaro. Did it myself by following his steps. Even I have trouble finding the chip sometimes. Yours is in a bit of a tricky area, but it looks small. This might work well for you.
#14 |
![]() Drives: 2016 Summit White 2SS Join Date: Jan 2016
Extremely minor avoid painting any big sections if you can will likely open a can of worms.
Good luck
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold 2008 Cobalt SS/TC Sold 2016 Camaro 2SS Summit built 3/28/16 delivered 2018 Camaro ZL1 cancelled by GM 😡 2019 Corvette 2lt Z51 |
