TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 09-24-2009, 06:51 PM   #1
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Scrming's Air Intake Experiment - Part II
Well... wasn't quite ready to post this up yet... BUT.. since I kind of let the cat of the bag... here we go....
Since the IAT relocation experiment went so well, I decided to tackle the intake tube.
Now when I first got my car I had asked Scott from MRT what that big appendage on the left side of the intake tube ways since I had really never seen one like that... He explained it was a silencer/resonator. That it's function was to help eliminate intake noise. And as we all know it does a great job! Even with a K&N filter and the stock snorkel off you cannot hear ANY intake noise!
Scott went on to explain that the silencer/resonator works but it does disrupt the air flow going into the throttle which in turn has a negative effect on performance! Since I don't mind the sucking sound I figured I needed to lose the silencer... First thought was to just cut it off... but I backed off that idea....
So one day walking through the auto parts store I happened to see some universal CAI kits and parts... Hmmm... So I decided to buy some of these parts and see if I could put together my own intake tube.... So I bought a handful of stuff and headed home... and this is what I came up with!
SO...
90 degree elbow, vacuum adapter, 45 degree elbow. I had to cut the 45 degree elbow.
Stock vs new...
The stock silencer/resonator... it's like a figure 8...
The hole for the silencer...
And the hole for the pcv connection... again right before the TB...
and now... the new tube installed.
and finally... a little video clip... (listen with your headphones)
BETTER VIEW!
Here's the part list:
Spectre - Air Intake Tube - Part Number: 8698 - $10.00
Spectre - Air Intake Vacuum/Sensor Adapter - Part Number: 8707 - $11.99
Spectre - Air Intake Tube - Part Number: 8738 - $11.99
Spectre - Coupler/Reducer Combo - Part Number: 8771 - $7.99 - This is for the throttle body connection
Ok.... the coupler for the tube to the air box is a RUBBER coupler... I bought the whole thing as a big kit - Spectre 8208. See: http://www.streetsideauto.com/produc...GoogleShopping
The 8208 came with a RUBBER coupler, not the more stiff silicone coupler... however with the 8208 you still need the 90 degree elbow....
Also needed a piece of hose... so basically did this for $50... you may be able to find the piece cheaper online... I just bought them at the local part store...
Big day will be Saturday... Car goes on the dyno! It is a "Dyno Day" though so I'll only get a couple of pulls... unlike when I buy my usual dyno time where I get 4 or 5 pulls... Since I like the way this turned out I'm thinking I will just dyno the IAT relocation and new tube all together....
scrming is offline   Reply With Quote
Old 09-24-2009, 06:54 PM   #2
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
very cool man.. props to you.
franknbeans is offline   Reply With Quote
Old 09-24-2009, 07:00 PM   #3
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Nice job srcming! How loud is it from the inside of the car? Under load? Looking forward to your numbers on the dyno!
Icefsh is offline   Reply With Quote
Old 09-24-2009, 07:04 PM   #4
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Nice work and thanks for sharing. I'll be looking forward to your dyno results.
67 GTO is offline   Reply With Quote
Old 09-24-2009, 07:21 PM   #5
scrming
scrming's Avatar
Thanks guys...
I really haven't got on it really hard so I'm not sure if you can really hear a difference in the cabin...
Old 09-24-2009, 07:47 PM   #6
viper1cobra
Member Club Elite #131
viper1cobra's Avatar
Drives: 2017 50th Anniversary H50 2SS
Great job, it looks very nice.
viper1cobra is offline   Reply With Quote
Old 09-24-2009, 08:06 PM   #7
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Awesome job man, thanks.... can't wait to see your dyno numbers!
CatiaJockey is offline   Reply With Quote
Old 09-24-2009, 08:39 PM   #8
Broncho
Drives: 2010 Camaro
Scrming, what auto parts store did you buy those items at?
Seems like I saw some CAI items at Auto Zone the other day.
Do you have a part# for the hose?
Thanks again for another excellent low budget V6 mod to
share with us.
Broncho is offline   Reply With Quote
Old 09-24-2009, 08:46 PM   #9
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
Nice job.........
The photos are really GREAT !!!!.........
..for sharing
97one is offline   Reply With Quote
Old 09-24-2009, 09:09 PM   #10
CamaroBAMF28
Drives: Black 2LT RS
ur a genius haha.
CamaroBAMF28 is offline   Reply With Quote
Old 09-24-2009, 10:37 PM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
wow that does sound awesome. And you are genious. I want your exact set up, sorry to be a copy cat but your exhaust just sounds the best. Great work. I get excited everytime i see a thread by Screaming!
TJ91 is offline   Reply With Quote
Old 09-24-2009, 11:42 PM   #12
Phizwit
Phizwit's Avatar
Drives: 2
agreed. this is why I will be heading to MRT as soon as my car gets here to get the scrming special.
Phizwit is offline   Reply With Quote
Old 09-25-2009, 05:15 AM   #13
scrming
scrming's Avatar
Thanks all!
I got the stuff at O'Reillys - http://www.oreillyauto.com
Sorry, no part number on the hose... just got a chunk of 1/2 inch (i think) flex hose and cut it to fit.... I have some left over at home... i check to see if it says what size it is...
Old 09-25-2009, 07:37 AM   #14
dagolfguy
dagolfguy's Avatar
Drives: 2010 Camaro 2LT RS
Scrming,
You did a fantastic job on this experiment. I think we are all hoping that the dyno or track numbers show it to be a good performance mod. We already know it's a good cosmetic mod. I want to do it!
Two questions:
Do you think the aluminum tube will contribute to heating the air entering the engine more than the plastic OE part does? The metal will absorb the heat more and retain it too.
Also, do you have concerns that there is enough flex and give in the joints you constructed on the new part so that when the engine torques and the air box stays put, everything will remain connected? The OE part has that accordion joint on it.
Keep up the great work and thanks for sharing your ideas with us!!
-Dave
dagolfguy is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 05:56 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 08:33 PM
ADM Performance Cold air intake makes 18rwhp and 18 tq over stock airbox ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 129 11-10-2009 07:29 PM
Which cold air intake should I buy? VictoryRed08 General Automotive + Other Cars Discussion 8 12-14-2008 08:36 PM
What Cold Air Intake should I buy? VictoryRed08 5th Gen Camaro SS LS LT General Discussions 2 12-14-2008 11:47 AM
