#1 | |
![]() ![]() Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
Mobile Phone Signal Boosters
I was curious if the Camaro 4g LTE Antenne could be hacked and turned into a Cellphone signal booster...
The 4G LTE Wifi is a joke.... why would you pay GM $60 a month for data when I am already paying for data on my phone? What is smarter is BOOSTING the signal getting to your mobile phone and using that as a hotspot... What I am curious about is using the large sharkfin as a signal booster as a part of a system like this... https://www.wilsonamplifiers.com/cel...-booster-guide anyone have the technical know-how to tell me if its possible?
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 02-22-2016 at 12:41 AM. |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
This is very interesting and something I will be following to see if some one does it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Car Join Date: Jun 2010
Well, that's going to depend on how easily you can access the software that's controlling the radio components and if it'll interconnect with cell towers in such a mode (basically a repeater).
I'm not a cell cracker or EE/RF Engr myself, so I don't know the ramifications of doing such things or if you would just splice off the antenna wiring (thought that was interlinked with the OnStar uplink though). |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Really that makes way more sense than paying separately for your car to have an internet connection. It would have been cool if they made it capable of both functions. Either a hotspot or a signal repeater. I know a mobile repeater would be stupid advantageous here in North Dakota. There's a ton of cellular dead spots.
#5 | |
I know OnStar uses AT&T networks, so guessing it's sim card based. Not sure if that means it will work for other fequencies like Verizon and Sprint.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#6 | |
You don't need jack up anything at that point. Just make a trip to Walmart and grab a mobile antenna, some wire and some 3M tape. I would think the whole point of the venture is to have something offloading your cell handling, and then to repeat it locally to your phone amplified, for use in low signal areas. Most of those devices I've worked with are all powered. |
#7 | |
Now if you can tap into the signal wires for the antennae and keep OnStar connected, your phone will have access to that better antennae. But then you really haven't done anything different than a booster like in the OP, since you are loosing any amplification or tuning done by myLink. Sorry I might not have been clear in my first post.
#8 | |
Anyways, was just going off what I see in the phone hacking side to allow for unlocked WiFi piggy backing for data.. and the powered cell boost amps I see.. All the passive ones have never worked out too well... And, I've had to deal with cell signal complaints years back on the 55th floor of the Prudential tower here in Chicago and we ended up going through a couple different catch/repeat systems with lengthy cable runs, amps and various antennae. |
#9 | |
![]() There just doesn't seem to be an easy way make it pay off. If there is, like you said, it will likely have to be licensed by the FCC. And I don't see them doing that with current focus on "securing" connected car tech.
#10 | |
Though, if someone makes Cyanogen Mod for MyLink with that.. I'm all over it. |
#11 |
![]() Drives: 2016 Camaro SS | 2001 BMW 330i Join Date: Jan 2016
If you have AT&T, you can add your vehicle as a device (just like a tablet) to your mobile share plan for $10/mo. You don't have to pay for any extra data this way, and just use whatever's already on your cell phone plan.
2016 Camaro SS
2SS Hyper Blue on Kalahari 6-speed manual Dual-mode performance exhaust Magnetic Ride Control |
#12 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
#13 | |
As it states, you can do either Mobile Share OR OnStar data plan. No need for both.
2016 Camaro SS
#14 | |
