Old 02-21-2016, 01:35 AM   #1
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
Upgraded Sound Systems?
So who is doing big upgrades to their sound systems? Bose or Regular?
I'm getting the Bose obviously but I am still curious if anyone will be looking into improving on it.
For instance, my current car has the Bang & Olufsen system which is pretty fantastic other than the subwoofer frequencies. So most of us have taken out the stock tiny subwoofer and put in 10-inch subs in free-air setups to great success. Wondering if the Bose system needs anything like that or more drastic additions to at least cover the audible range.
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 02-21-2016, 06:04 AM   #2
suzook
Drives: camaro
The stock Bose sounds great, but could use a little help in the sub dept.
Hyperblue/JetBlack
Old 02-21-2016, 08:32 AM   #3
laynlo15
Drives: 2022 Lt1 A10
I've done the Memphis rear deck speakers with Memphis amp. Sound pretty dam good.
Old 03-01-2016, 03:07 PM   #4
Lethalphoenix
Lethalphoenix's Avatar
Drives: 2013 SS// 2016 SS
Going all out with component JL's in front and JL coax in rear with 2 12" JL W6 subs in the trunk. All said and done should be about 3k with all the amps connections ect.
Lethalphoenix is offline   Reply With Quote
Old 03-01-2016, 03:14 PM   #5
FlightSoftware
Drives: '95 Corvette, '06 Mustang, 2LT RS
I know several people on here like the Bose. And it may be pretty good for a car stereo, but honestly I think at least some new speakers would help.
I have Axiom Audio at home, so I'm a little picky. But the bose in my 2LT sounds worse to me than the Shaker system in my '06 mustang. I'm going to try some higher bit rate MP3s just to make sure it isn't the audio source. The speakers just don't thrill me... I've played with the limited eq and it thumps ok, if that's what you like, but there's not much higher freq stuff... no definition, it's not crisp (to me).
Don't think it's the installation, or there's a problem. I think it's the typical "No highs, no lows, must be Bose" phenomenon.
Mosaic Black 2LT/RS, V6, manual, dual mode exhaust, heavy duty brakes, adrenaline red, lighting and convenience package, black bow ties
FlightSoftware is offline   Reply With Quote
Old 03-02-2016, 12:14 PM   #6
bpang1234
bpang1234's Avatar
Finally someone who I am looking for.
I enjoy having bass but I don't need a huge system like the other guy. Just appropriate additions to the stock system to get it up to a nice level of definition.
I really am spoiled by the Bang & Olufsen system in my Audi and I know that Bose has never really made anything comparable (at least from all the cars I've been in). At best, I hope it is just a change to better front speakers and better subs that would do the trick...I really don't want to deal with a full system if I don't have to.
2016 Camaro 2ss
Old 03-02-2016, 02:39 PM   #7
Luigi91
What irritates me the most is how much vibration there is in the door panels from the speakers. Really want to get a good 12-15" sub in the trunk to take away some of those lower frequencies from the Bose speakers.
I have found that you really have to turn up the midrange on the EQ with these Bose speakers to make them sound even decent...but once you get the EQ right, they are pretty good.
Luigi91 is offline   Reply With Quote
Old 03-02-2016, 05:32 PM   #8
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
With these oem setups, isn't a lot of the low and high pass filtering and tweaking of the equalizer (other than the dummy one they give you access to in the head unit) mainly handled by the oem amp.
It seems unlikely you'll be able to correct what you believe is wrong with the Bose system without replacing the stock amp so you have full control over the various channels and can undue the Bose speaker specific modification they are using since you are no longer using bose speakers.
if i were going to modify the audio system, replacing the amp would be first before replacing any speakers. Then I'd be able to correct the bias they have for front speakers and start from a clean state that I have full control over as far as filter sand sensitivies and bass boosting. etc.
Old 03-03-2016, 12:41 PM   #9
ussj4brolli
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT
i had an older Eclipse amp that was made by Bang & Olufsen and it was the greatest amp ive owned. I had 1 amp hooked up to 2 Eclipse Titanium Sw9122`s and my Camaro shook apart. I had an amp for the 4 upgraded speakers, too.
Unfortunately right now i am literally trying to figure out how i hook things up to my deck. I have a 1LT RS with a 7in and i do NOT have the rear amp, so im digging around trying to find out how these are connected and what i can do. I want two amps in my car - one .4 and one .1. I have the non-bose system so i "require" this to be crisper, cleaner, and louder.
ussj4brolli is offline   Reply With Quote
Old 03-05-2016, 11:07 AM   #10
AC48
Drives: '16 2SS
I'm also curious about doing some upgrades at some point to the audio system. Where is the amp located on the Bose set up? Does the 8'' head unit act as the amp for the system or is there a separate amp located somewhere else in the car? I'd love to be able to get at the amp and replace that while adding a small sub without having to tear apart half the interior of the car. I did that with my last car and granted it was an Evo, it rattled like crazy after tearing apart the interior to wire everything up and reinstall.
I'd like to play around with the stock speakers once a lot of the lows are taken care of by a sub so see if I could get away without replacing them. I had JL Audio component fronts and coax rears with a sup set up in my Evo, sounded great, would be even better with a car that actually has some sound deadening in it.
AC48 is offline   Reply With Quote
