Old 02-10-2016, 03:30 PM   #1
CleanAss
Drives: 2016 Camaro SS
Preparing SS for track day
I'm almost past the break in period and I can't wait to try out the "competitive mode" on the track in march, before I bring it to the streets
From reading the owner's manual there are 2 things that need to be done:
- replace break fluid with high temperature one
- replace plastic shielding around the breaks with less restrictive one (I have it from factory)
Has anyone done this or has opinion on how necessary this is? Any recommendation on the break fluid?
Thanks!
CleanAss is offline   Reply With Quote
Old 02-10-2016, 04:11 PM   #2
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
If your at it frequently or an all day event with 100 degree weather I'd say change it to DOT5. Otherwise, if your going to do it once in a blue moon I'd see no real reason to change it. Maybe flush it more frequently.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-11-2016, 09:16 PM   #3
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
Think twice about using DOT 5. Do your research... and read this thread:
http://www.camaro5.com/forums/showth...=425672&page=2
Have fun!!
Best regards,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 02-20-2016, 12:22 PM   #4
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
Motul ore ATE brake fluid will be all you need.
JTRATX is offline   Reply With Quote
Old 02-23-2016, 07:20 PM   #5
dieme1rc
Drives: 2016 Camaro 1SS
Motul 660
Motul 660 is what we use in our Corvette when we race it. it works great.
dieme1rc is offline   Reply With Quote
Old 02-24-2016, 01:16 AM   #6
backeddy
Drives: 2011 Boxster Spyder (best car ever)
ok, not to be rude, but someone who reccomends dot5 needs to be kept far away from the track. Dot5 is not compatible with 3/4 and frankly, it boils like water. I only recommend Castrol SRF, as I have boiled every other brand. I like carbotech pads too, but be sure they are ducted
backeddy is offline   Reply With Quote
Old 02-25-2016, 04:41 PM   #7
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
I have a full bottle of Ate Super Blue never opened in my garage waiting for my 2SS!!!
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 03-03-2016, 02:57 AM   #8
mcynet
mcynet's Avatar
You can't use dot 5... I use caster oil SRF best stuff there is.... but they know it and charge for it. It works wet so it last longer
Drives,
2016 Camaro 2 SS,
(OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging
mcynet is offline   Reply With Quote
Old 03-08-2016, 09:54 PM   #9
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Dot 3/4/5.1 are all compatible
Dot 5 is Sillicon (iirc) based and not compatible with the Camaro braking system, nor is it compatible to mix with Dot 3/4/5.1 fluid
thescreensavers is offline   Reply With Quote
Old 03-08-2016, 10:11 PM   #10
toehead93
Drives: 2014 2SS/1LE
Running on a track with dot3 is dangerous IMO and if you could only do one thing I would change to dot 4. Make sure you have at least half the pads left. Braided brake lines help with pedal feel too. You can also get a more aggressive alignment which will let the tires grip better and wear more evenly.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 03-09-2016, 01:28 AM   #11
bpang1234
bpang1234's Avatar
I have a full can of Ate Super Blue never opened waiting for this car!
2016 Camaro 2ss
Old 03-09-2016, 07:17 AM   #12
Imp
Dodges all the cones
Imp's Avatar
Drives: Soon
Wait... what?
Did you mean Castrol?
--kC
Imp is offline   Reply With Quote
Old 03-09-2016, 07:19 AM   #13
Imp
Imp's Avatar
Drives: Soon
Yep.
--kC
Old 03-31-2016, 08:26 AM   #14
Hyper16
A Heartbeat Away.........
Hyper16's Avatar
Originally Posted by Imp View Post
Wait... what?
--kC
LOL
