Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
2016 2SS - Mysterious Rattle has Appeared
If things can't get any worse...
Today after 3 days of the car sitting all tucked away in the garage, I started the car up like normal. Sounded great as always. Took off down the street and upon swapping the car into Sport mode and hitting the gas lightly a vibration rattling sound could easily be heard from the passenger rear side of the car. shit.... So thinking to others posting NPP issues when the valves were closed... but mine was open. Could it be something else I though? So I started to change the NPP modes and the sound happens in every mode selection. Running the car idle and parked dosen't seem to reveal the location of the sound, but only while driving under light load and being on the gas peddel. I am going to try and find what is causing this, but chalk it up as another fun early production potential issue.
Camaro Fan
Damn that really sucks! Is it a loud rattle?
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
Lethal Camaro
It is pretty audible when it is making the noise.
davet
Drives: 2016 2SS Mosaic Black Join Date: Apr 2010
You said it's vibrating also? You don't have a loose wheel do you?
Damn Sledgehammer your luck is like mine,
Replacement car ordered 2/02/2016
2/03/16 2500 2/04/16 3000 no TPW 2/8/16 3000 TPW 2/29 2/18/16 3400 3/3/16 3800 3/4/16 4B00 3/5/16 4300 3/7/16 4200!!! |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
That sucks man, I've seen guys use a gopro under their ride to locate hard to find noises.
Good luck and hope it's nothing big
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: camaro Join Date: May 2013
Hyperblue/JetBlack |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
Can you reproduce it by reving the motor up while in neutral?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
#8 |
Camaro Fan
Throw that GoPro Back there. Get an extra one from "work" to put on the side/back/under the car
#9 |
![]() Drives: 2018 ZL1 1LE Join Date: Jul 2009
Mine has been like that since day one. Just really don't want to take it in and leave it at the dealership for weeks until it gets fixed. Might have them look at it when I get the software update for Android auto in a few months.
#10 |
![]() Drives: 2017 Hyper Blue 2SS Join Date: Jul 2015
It might something simple as a loose bolt. I had the issue with the sport mode and I kept hearing a rattle as well (have NPP exhaust as well) the dealer tighten a couple loose bolt and the noise stopped.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
Sounds like my issue. Does yours sound like this. https://www.soundcloud.com/i007spectre/2016-rattle
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
#12 |
![]() Drives: 2016 2ss garnet red soon Join Date: Aug 2015
I have a similar issue. Rattle on the right exhaust pipe. I took it to the dealer last week to have them look at it and my passenger seat not reclining. They said the exhaust issue was a known problem and they had to order some lube from the factory. It's in now and I have an appointment on Thursday to get it fixed. The seat was just a loose connector.
2SS Black/Adrenaline Red
#13 |
Well I have narrowed my rattle down to the pass side NPP valve. I took a screwdriver, gave it a few swift blows...noise is gone for now. OP, check your NPP valve. Just stick a long screwdriver in pipe against it, and see if noise goes away?
#14 |
Lethal Camaro
The issue for me only appears when driving. You can't hear or notice it while it sits idle. The car is headed to the dealer on the 8th, will have them look at it than. I am going to see if my gopro can pick up the noise.
