Old 01-27-2016, 08:26 PM   #1
Imtheboss
Drives: White 1lt sunroof NPP
Cat delete on NPP
I want to take the cats off for added sound on a v6, is there anything I should know before doing it, and would it have any negative affect on the npp system?
Imtheboss is offline   Reply With Quote
Old 01-27-2016, 09:00 PM   #2
CAPerformance16
CAPerformance16's Avatar
Drives: 2016 Camaro 1SS A8
It will throw a CEL for the missing cats, but that can easily be tuned out. As far as the NPP it will work as normal, just alittle louder.
2016 1SS A8
7.9 @ 90.79 Stock with a tire
7.20 @ 94.71 LBO getting kicked out
Now tuned on E85, CA Performance Test pipes & Circle 4C 3800 stall shooting for low 7's next time out.
CAPerformance16 is offline   Reply With Quote
Old 01-27-2016, 09:30 PM   #3
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
Cat delete in California? Good luck...
BahamaTodd is offline   Reply With Quote
Old 01-27-2016, 09:33 PM   #4
laynlo15
Drives: 2022 Lt1 A10
Not a good idea in Cali. Could cause other issues also. Should of had a V8.
Old 01-27-2016, 09:35 PM   #5
CAPerformance16
No smog inspection for 5 years when new and even then nothing knowing a few people can't fix. Just don't act a fool and get ref'd. I daily drove a 650rw Turbo 4th Gen SS with dumped exhaust and never once had an issue.
2016 1SS A8
Old 01-28-2016, 04:20 AM   #6
Imtheboss
Thanks for all the great advice, also would a high flow cat be able to get the job done?
Old 04-21-2016, 09:04 PM   #7
Eljefe619
Drives: Black on black 2ss
So I did the the cat delete on a 2ss and cut out the 2nd cats also there were no cel at all. The car is loud a Lil raspy in the rpm range but sounds good lost a bit of bottom end.
https://youtu.be/J7F0Quf2JUk
Eljefe619 is offline   Reply With Quote
Old 04-22-2016, 08:08 AM   #8
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
Camaro*
Lucely Engineered is offline   Reply With Quote
Old 04-22-2016, 08:10 AM   #9
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You can elim 2nd cats no problem. Makes a diff ....search for my post with pics here....
Old 05-18-2016, 12:48 PM   #10
ScottySheppard
ScottySheppard's Avatar
Drives: 2016 2LT RS
Did a quick check with a lot of the muffler shops in my area (Reno/Carson City) and nobody will touch the job. All say it's a $2500 fine (nationally) if they get caught doing it. Any suggestions?
2016 Camaro 2LT, RS, Hyper Blue, Med Ash Gray, Silver Rally Stripes, Advanti DST Titanum Mirror Wheels, LGX, 6M, IO6, NPP, ZN2
11/30/15--1100
12/10/15--2000
12/16/15--3000
01/06/16--3300
01/07/16--3400
01/25/16--3800 1G1FC1RS8G0142935
01/25/16--4000
01/27/16--4B00
02/06-16--4300
02/22/16--6000
ScottySheppard is offline   Reply With Quote
Old 05-31-2016, 03:29 PM   #11
ScottySheppard
Drives: 2016 2LT RS
Found several hot rod shops that will do it. I guess you need to use a 2 3/4" stainless pipe or it might through a code. Anyone confirm?
11/30/15--1100
12/10/15--2000
12/16/15--3000
01/06/16--3300
01/07/16--3400
01/25/16--4000
01/27/16--4B00
02/06-16--4300
02/22/16--6000
