Old 01-22-2016, 08:48 AM   #1
BlkReaper
Drives: 2016 2ss
Parking brake not releasing and no hill assist
I have a ss manual. I believe the parking brake is supposed to release when the car is in gear and the gas is pressed. Sometimes randomly the parking brake does not come up and I have to press the actual button. Also I stop on some steep hills everyday and I've only seen hill assist come on once. I don't even bother trying anymore and just hold the clutch in the sweet spot.
BlkReaper is offline   Reply With Quote
Old 01-22-2016, 10:09 AM   #2
ussj4brolli
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT
Dealer bro!
Hill assist works on my RS. And the brake DOES come off when hitting the gas.
ussj4brolli is offline   Reply With Quote
Old 01-22-2016, 10:32 AM   #3
jimmypop13
Drives: 2016 camaro ss
You have to give it enough force with the gas pedal to make the parking brake disengage. But why are you doing it like that? Just push the button down in the opposite direction and it will turn off. Are you trying to use it for small inclines where hill start doesn't come on?
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 01-22-2016, 01:59 PM   #4
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
Originally Posted by BlkReaper View Post
I have a ss manual. I believe the parking brake is supposed to release when the car is in gear and the gas is pressed. Sometimes randomly the parking brake does not come up and I have to press the actual button. Also I drive on some steep hills everyday and I've only seen hill assist come on once. I don't even bother trying anymore and just hold the clutch in the sweet spot.
My clutch would not like you riding it like that, just curious, do you smell anything?
Old 01-22-2016, 02:22 PM   #5
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
I have a 1ss and the proper way is hold your foot on the brake and push down. Then when you park, foot on brake and pull up on the button. The hill assist kicks in when you rock back and forth. Do not hold the clutch in the "sweet spot" This is how you burn a clutch up. Just letting it barely keep slipping or rest your foot on the clutch while you drive will glaze the flywheel. Kind of like if you just ride your brakes. Think of a clutch as an on and off switch for longevity. Obviously to induce a sideways drift can feather the clutch. Although these cars do not need any thing more than throttle.
drivingagain is offline   Reply With Quote
Old 01-22-2016, 02:59 PM   #6
BlkReaper
Drives: 2016 2ss
the manual says the parking brake should disengage when the gas is pressed.
Old 01-22-2016, 03:00 PM   #7
BlkReaper
Drives: 2016 2ss
I have no problem turning on and off the parking brake with the button. the thing is the manual says it should disengage when the gas is pressed. Also can you further explain what you mean by rock back and forth? when i say im holding in the sweet spot i mean when i am stopped on a hill. Its either that or roll backwards when going from brake to gas. there is no glazing in that action
Old 01-22-2016, 03:01 PM   #8
BlkReaper
Drives: 2016 2ss
There is no riding of the clutch or slipping. i am talking about being stopped at a light on a hill
Old 01-22-2016, 04:52 PM   #9
Ragnar
Ragnar's Avatar
Drives: Wife's car
, Holding the clutch got me to ask the question. On my car the HA will not activate if you pull the e-brake one click. But when it does activate, it takes about 5 seconds, no matter what you do.
Old 01-22-2016, 06:57 PM   #10
BlkReaper
Drives: 2016 2ss
Oooo OK, so 5 seconds. I usually never wait 5 seconds because by that time someone will be on my bumper. I'll try that sometime when the snow clears.
Old 01-22-2016, 08:46 PM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I understand that to be a "backup" feature to prevent you from driving down the road with the parking brake on...I admit, I haven't read the manual. Does it say that that's how it's supposed to work?
Old 01-23-2016, 08:51 PM   #12
BlkReaper
Drives: 2016 2ss
here is the manual
Old 01-25-2016, 08:16 AM   #13
Mr. Wyndham
So it sounds like it can be done...just not all the time.
Old 01-25-2016, 06:06 PM   #14
C5Txfan
C5Txfan's Avatar
Drives: 2004 Corvette
a fast way to burn up a clutch !!
C5Txfan is offline   Reply With Quote
