Cargo net
The 2016 Ss I have doesn't come with a cargo net like my 5th gen does in the trunk why is that? I have some caNs back there flying around ... Is it only me or does all the 6th gen have none? And I have splash guards in the trunk do I have to put those on it says for performance track use so only use if on track?
Retired from Car mfrs....
Its an accessory .....full review with pics here:
http://www.camaro6.com/forums/showthread.php?t=435069
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
It's an option when u order the car. Mine came with one. It's installed by the dealer when the car arrives or they can leave it in the box for you to install at a later time. I just installed mine today. It's quite small
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
#5 | |
davet
Drives: 2016 2SS Mosaic Black Join Date: Apr 2010
You only put those on when running it on a track. It will increase air flow over the brakes. They aren't splash guards though.
Replacement car ordered 2/02/2016
2/03/16 2500 2/04/16 3000 no TPW 2/8/16 3000 TPW 2/29 2/18/16 3400 3/3/16 3800 3/4/16 4B00 3/5/16 4300 3/7/16 4200!!! |
![]() Drives: 2016 Mosaic Black 2SS Join Date: Dec 2013
Cargo net ? 50 buck hair net....that's about it ...useless for much of anything
#7 |
#8 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Cargo net still is useful but not 50 bucks useful. If I had known, I wouldn't have bought it. At least not for 50. But for 20.
#9 |
![]() ![]() Drives: 2016 2SS Garnet Red Camaro Join Date: Aug 2015
The cargo net is $60.00, not $50.00.
Ordered: 8/8/15, 2SS Garnet Red
Built: 10/14/15 Current: Took Delivery, 12/24/15 Added Procharger supercharger. ![]() |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Cars Join Date: Feb 2009
I ordered both the cargo net and the rubber trunk mat with my 5th gen, and thought they were both worth having. They keep things from sliding around in the trunk, especially groceries and smaller items.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS Join Date: Apr 2013
Somebody on the forums stated that to use the cargo net, you need to replace a couple hand-turn fasteners on the rear plastic liner of the trunk with some fasteners that come with T-shaped hooks. This gives you your anchor point for the cargo net. See the thread linked in the 2nd post for pictures.
#12 | |
![]() Drives: 2018 Camaro ZL1 1LE Hyper Blue Join Date: Dec 2015
I also have to other plastic parts with no indication as to what they are. Their part numbers are 23383583 & 23383584. I Googled all of them and they show a GM part, but no description was available. Thanks, Howard
2018 ZL1 1LE Hyper Blue Metallic
2005 Silverado 2500HD Crew Cab 1987 Camaro IROC-Z White T-Tops Instagram @Gen6ZL1 |
#13 |
![]() Drives: 1968 Camaro SS 350 Join Date: Nov 2015
i have the net.... It's so small but works good for something really small like a collapsible umbrella LOL! Basically a $60 umbrella holder
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill |
#14 |
It's great for holding detailing spray bottles.....
