Automatic in manual mode?
Does the automatic when in manual mode switch gears if you hit the Rev limiter.
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging |
I tried one. It said shift denied when in track mode and trying to downshift from 3rd to 2nd at 4k rpm
Drives,
![]() Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT Join Date: Nov 2015
I dont (think) so. I was in Manual mode and bounced off the REV in first before...it was an opps. Although, i have not tested this in NON-Manual mode selected but MANUALLY shifting. Yes, you can manually shift gears with the shift knob in auto.
I liked that my 4th GEN if slammed into first it will shift to 2nd when needed. Helps me control the car at a 35mph burnout. |
That would put the rpm around 5500 or so I don't know why it denied the shift
Drives,
Im at the dealership and just tried it again, I'm in manual mode... again shift denied. Is there some way to change it, I'm looking at buying one today, but I autocross so I have to be able to control the shifts. I want an auto but not if I can't downshift.
Drives,
I think throttle position would factor into the shift too, not just the RPM.
See if there are an option to change this in the settings in the player under car settings. I can downshift whenever i want i believe, i will test this in just a few min. |
#7 |
#8 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
If you want full control, buy a manual. The manual mode on the A8 doesn't give you 100% control, and still has some nannies and torque management...not to mention delayed upshifts at WOT. |
#9 | |
I see a delay at Non-wot, though. |
#10 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
As described by Tadge Jeuchter (head engineer of the C7) the reason there is a delay when you manually change gear with the paddles is that the signal is sent to the cars ECU and it checks with all the cars sensors to make sure shifting to the desired gear doesn't upset the car and cause a dangerous situation. Then it shifts... if it's safe. Apparently if it isn't it taunts you with a "shift denied" message
![]() Now, if you leave the car in "D" / automatic mode, and run the car in Track mode, you will have super quick shifts / holding gears higher into the rev ranges / etc - all without driver input. That is what Chevy means when they say that the 8 speed "shifts nearly as fast as a PDK"...when you leave it to do it's thing, when it wants to shift, and the computer executes the command to shift, it does it on par with the best DCT made today. They acknowledged the delay from hitting the paddle to the 8 speed shifting gears. It is by design.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#11 |
![]() Drives: 2016 Camaro 2SS Join Date: Jan 2015
#12 | |
It would be cool if the computer could "learn" from your style of driving and reduce shift delay over time if you can prove that you don't make dumb or poorly timed shifts. For example, if you were a capable driver and it learns that you're always making proper shifts, it'd be nice to see that delay reduced over time once the computer starts to "learn or trust" that you know what you're doing. On the flip side, if the computer see's that you're constantly making poorly timed shifts, well, then the delay stays. |
#13 |
マスタング = 遅い
There is always a delay. I was told just this past Saturday by an engineer on the GM Performance Tour that it can't be 100% eliminated due to the type of transmission and the electronics...sometimes it's better, but there will always be a slight delay from paddle pull, to when the transmission upshifts. I've driven three C7's and two SS's and they all did just this...
#14 | |
That's 250-500ms then, not really much a delay....just some people can notice it more than others. A pro driver would have difficulty consistently making a shift happen in that time span.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
