Old 01-15-2016, 06:07 PM   #1
TheVENOMZ
TheVENOMZ's Avatar
Drives: 2016 Black SS M6
Shifter rattle
Anyone else getting a small rattling from the shifter? When in 3k+ rpms?
Only seems to rattle in the top numbers
1,3,5 gears
I'm thinking something is loose. But I have no idea how to open it to see. I guess taking it to the dealer is my only option. I just don't want anyone driving my car.
Any thoughts?
TheVENOMZ is offline   Reply With Quote
Old 01-15-2016, 06:16 PM   #2
stratt
Drives: Waiting on my 2016 Camaro 2SS
I thought I was the only one. Weird if you push up on the shifter, the rattle stops.
stratt is offline   Reply With Quote
Old 01-16-2016, 08:20 AM   #3
TheVENOMZ
TheVENOMZ's Avatar
That is the exact thing that happens to mine. Weird.
Old 02-24-2016, 09:53 AM   #4
Danew_377
Chief Bief
Danew_377's Avatar
Drives: Nightfall Gray Camaro 1SS
I have that as well.
Danew_377 is offline   Reply With Quote
Old 03-02-2016, 04:49 PM   #5
bobshannon22
bobshannon22's Avatar
Drives: 2016 camaro 1ss
I also have about .5 inches of left to right movement. Glad it's seems normal
2016 1SS (M6) Kooks headers and exhaust, pray ported MSD/TB, JLT CAI, JLT catch can, TSP heads/VVT-2 cam, E85, Centerfirce clutch, g force axels and DS, most of what BMR makes, blah blah blah
bobshannon22 is offline   Reply With Quote
Old 09-16-2017, 05:13 PM   #6
Camaro6.SS
I am having the same issue with mine. The rattle doesn't sound like it's coming from the shift lever itself but applying gentle forward pressure on the stick temporarily silences it.
I brought the car to the dealer, and they performed the procedure described in TSB 16-NA-078, but unfortunately it had no effect.
Has anyone had any luck diagnosing/solving this issue?
Camaro6.SS is offline   Reply With Quote
Old 09-16-2017, 05:15 PM   #7
Wiskey
Drives: 2016 Chevy Camaro
I have that too!!!! I thought it was just me! I told my dealer about it and they simply said that sometimes it's normal for cars make noises. Glad to know I'm not the only one!
I'll be following this closely.
Whiskey
Wiskey is offline   Reply With Quote
Old 09-18-2017, 11:24 PM   #8
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Do the tsb procedure yourself, dont trust the dealership to do it right. It worked for me. Generous amount of blue thread locker.
soloknight6 is offline   Reply With Quote
Old 09-20-2017, 10:40 PM   #9
Camaro6.SS
Yeah, I'll give it a try. I'm a little concerned that it might be something other than the retaining screw addressed in the TSB, because mine only seems to rattle in the forward gates/positions, i.e. 1st, 3rd (especially), and 5th gears.
Do you remember if your situation was similar?
Old 09-21-2017, 10:24 AM   #10
soloknight6
SoCal HT5! SD
Identical, usually occurred during decel, more vibration = more rattle.
Old 09-23-2017, 05:00 PM   #11
Camaro6.SS
Thanks for the info! I guess I'll just have to perform the TSB procedure myself since the dealer apparently failed to
Old 10-10-2017, 11:08 PM   #12
TimsZ28
Drives: '16 2SS, '14 Z71
Yep, just pop up the surrounding trim around your shifter. Locate the lock screw on the driver's side where the shifter handle connects to the shifter. Use a torx wrench to remove it, apply lock tight, re-install it... Can be done in about 2 minutes. I had the exact same sound. Not normal.
Now there are some normal sounds you can hear through the shifter obviously.
'16 2SS M6 & '14 Z71
TimsZ28 is offline   Reply With Quote
Old 11-17-2017, 03:07 PM   #13
Wiskey
I did this procedure on mine and it fixed my issue too!!! It was rattling every time I was going up hill in 3rd or 5th and now its nice and quiet.
Thanks so much for the tip!! The screw did not seem loose, I never would have guessed that this was the issue.
Whiskey
Old 01-26-2019, 11:46 PM   #14
sav03cobra
SS Copbait R.I.
Sorry for an old bump.
I did this TSB last night, life saver. I was so tried if the shifter rattle...worked for me perfectly.
sav03cobra is offline   Reply With Quote
