Old 01-15-2016, 11:21 AM   #1
ScratchAce
ScratchAce's Avatar
Drives: 2SS - Hyper Blue/Ceramic White
Almost on the train!
Just got word from the dealer that my car is on its way to the train yard in Toledo. It has been stuck in Lansing for weeks.
I'm in Colorado, anyone know approx how long it takes to travel on the train from Ohio?
2SS - Hyper Blue/Ceramic White, A8, MRC, Npp, Sunroof, Low-Gloss Black Wheels, White Rally Stripes.
ScratchAce is offline   Reply With Quote
Old 01-15-2016, 11:43 AM   #2
alfonsoj23
Drives: 2014 camaro ls
Congrats ! U should have it soon!
Hey how weird is it that I never hit 4200 status... But my car is already at 3800!!!
alfonsoj23 is offline   Reply With Quote
Old 01-15-2016, 12:12 PM   #3
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
4800?
When you get your Order Event History you should be able to see 4200.
Laborsmith
laborsmith is offline   Reply With Quote
Old 01-15-2016, 12:21 PM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Iron x the car when you get it, rail dust is so corrosive......
Old 01-15-2016, 12:54 PM   #5
ScratchAce
ScratchAce's Avatar
Looks like its pretty potent stuff...Is it necessary to use the TarX beforehand that is mentioned below or does that really depend on if there is visible tar or gunk on the car first?
FEATURES:
Removes Iron Particles and prevents the spread of iron-related damage & helps to protect your vehicle from paint system failure.
New Formula combines Cherry perfume to aid in masking Iron Dissolving Chemicals
Safe to use, Acid Free, and pH neutral (pH 6-7).
Safe to use on Clear Coat Paint
Safe to use on Aluminum, Chrome, Alloy, or Clear coated wheels.
Safe for use on all solid car surfaces and will not deteriorate clear coats. (Avoid using on Fabric Convertible tops)
DIRECTIONS:
1.-Shake the bottle.
2.-You can cover the surface with Iron X by spraying it everywhere but that can be wasteful. I recommend that you spray as needed and spread it with a small sponge or applicator to cover the entire surface. You may also consider using an atomizer type spray bottle or HVLP gun. In any case evenly cover the surfaces you wish to decontaminate. The product is strong so you don’t have to be wasteful. Just make sure it contacts the entire surface.
3.-Allow the product to dwell for 5 minutes in the shade. Do not allow it to dry in the sun. On light colored paints you will see the product dissolving ferrous particles as it turns color. On darker colored paints everything is happening in exactly the same way. It’s simply more difficult for you to view the color changing affect. I have read people saying the product works better on lighter colored cars but that is illogical and is not the case. It works the same regardless of car color.
4.-After allowing to dwell take a damp (not soaked) grout or other paint safe sponge (or other media if you prefer) and agitate the surface.
5.-Thoroughly rinse the surface.
Don’t forget to rinse your media out also. I like to have a dedicated Iron X sponge but that isn’t necessary.
PRECAUTIONS:
A.-Use outside or with sufficient ventilation.
B.-Use latex or Nitrile gloves, and face protection.
C.-If there is an inordinate amount of tree sap, tar, other organic material, wax, or sealants on the vehicle I recommend you strip them first with TarX so Iron X can attack the ferrous particles without any interference. This is not required but is how I like to do it for best results.
D.-For best results apply to a mostly dry surface. A few drops of water is ok
Old 01-15-2016, 01:05 PM   #6
cartem2
cartem2's Avatar
Drives: Nightfall Gray 2LT RS
Congrats, it's an exciting time, post pic's when it arrives
My Build Journal, Review, and Photos: Here
cartem2 is offline   Reply With Quote
Old 01-15-2016, 01:11 PM   #7
alfonsoj23
Originally Posted by laborsmith View Post
4800?
Laborsmith
Yup I'm gonna get it when I go pick it up, hopefully tomorrow!!!
