![]() Drives: 2016 camaro ss Join Date: Oct 2015
synthetic manual transmission fluid
does any one know what a compatable synthetic fluid we can use in the manual transmission. The owners manual reads on page 326
Manual Transmission Fluid (GM Part No. 88861800) witch is a mineral oil? http://www.summitracing.com/parts/ad...FRCNaQodxYUEkw https://my.chevrolet.com/content/dam...ro1stPrint.pdf
![]() Drives: 2021 Corvette Z51 Join Date: Dec 2014
Redline D4 ATF is the synthetic aftermarket fluid to use in the M6 manual transmission.
http://www.redlineoil.com/product.aspx?pid=51&pcid=9 Redline D6 ATF is the synthetic aftermarket fluid to use in the A8 automatic transmission. http://www.redlineoil.com/product.aspx?pid=115&pcid=9 |
#3 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Can't go wrong with Redline.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
thanks guys!
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
Amsoil Signature Series ATF.
Probably use this myself. I have seen many people use Redline manual transmission gear oil with their shock proof additives. I personally do not know about their automatic transmission fluid that is used now a days instead of gear oil. |
How many quarts does it take?
#7 |
I can't find the exact amount, but it should be around 4 quarts/1 gallon based on the gen5 and C6/7 capacities. I say buy 5 quarts (or a gallon jug + 1 quart bottle) to be on the safe side and you'll have plenty available. Report back with how much it actually takes please!
#8 |
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
I'd be careful about changing to synthetic in the auto. Many of the LSx message boards are full of people complaining about auto transmission slipping and acting odd when changing from the factory fluid.
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
#9 |
thanks man good to know. Im just curious about the 6speed manual though.
#10 | |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
#11 |
![]() Drives: 2015 Camaro SS Join Date: Feb 2016
tremec tr6060
The manufacturer website recommends ATF meeting the Dexron3 specifications.
They go on to say that they Do Not recommend synthetic fluid and state various reseaons. Not looking to start an opinion war here....as the above statement is not my opinion. Just passing along the manufacturer recommendation. Peace |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
i thought since they changed over to carbon blocker rings we were ok to use syncromesh and synthetics?
#13 |
after a little more looking, its not clear that every gear has them. it looks like only the ones that were historically problematic. so unless we can confirm otherwise, theres no way i would use anything other than the recommended oil
#14 |
![]() ![]() Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
Amsoil. Made the switch at 1500 miles. On OEM fluid, it would get HOT after about 12 passes on a strip. Now I can make 15 hotlaps and it never gets close to redline.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
