Old 01-11-2016, 05:16 PM   #1
The1DoubleN
Drives: Blown up '16 SS
LT1 Engine Manual / Guide from Chevy
Here's the installation manual from Chevy for the LT1, explains a lot about the engine:
lt1-crate-engine-dry-and-wet-sump-19328728-19329997.pdf
The1DoubleN is offline   Reply With Quote
Old 01-11-2016, 06:10 PM   #2
Toxicgoober
Drives: 2014 Maxima
I haven't seen that yet. Thanks for the info!
Toxicgoober is offline   Reply With Quote
Old 01-11-2016, 07:16 PM   #3
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Nice, thanks!
Old 01-11-2016, 09:15 PM   #4
Kracka
Drives: 2021 Corvette Z51
Great info, thank you!
Kracka is offline   Reply With Quote
Old 01-11-2016, 10:07 PM   #5
neal_zack
neal_zack's Avatar
Drives: 2016 camaro ss
Ive seen it already I found it weird that the breakin is so much different from the owners manual version its on sheet 10
Summit white, 2SS, Ceramic white interior, 6 piston brakes, Black Bowties, 6 Speed,3.9 sec 0to60 NPP,MRC,NAV,RX Catch can
neal_zack is offline   Reply With Quote
Old 01-12-2016, 08:25 AM   #6
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
That's because they are talking about a green crate engine with zero run time.
When buying as a complete car... the engine was run at the engine plant, run at the vehicle assembly plant, run at varying loads on the DVT test at the end of the line, run around the shipping yard, run around the rail yard, run around the dealership parking the car.... So, it has it's thermal cycles and varying loads already done.
The crate motor is going to be green tight. Need to give those parts the right loads and heat cycles to get to know each other.
If anyone ever says... drive it like you stole it from first key up... stop listening to them. You vary the loads, heat cycle it, and work your way up to max power.
Russell James is offline   Reply With Quote
Old 01-12-2016, 08:30 AM   #7
fastball
Drives: 2017 Camaro 2SS 6MT
Thank you. There are a few members on this forum who will swear you beat the engine to hell right out of the gate for proper break in.
Like I told them, it's their car they can do what they want, but don't tell others to do the same.
fastball is offline   Reply With Quote
Old 01-12-2016, 09:49 AM   #8
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
Yup. They forget they're not solely breaking in the engine. They have an entire vehicle to break in.
xgnxs is offline   Reply With Quote
Old 01-12-2016, 10:16 AM   #9
fastball
And these cars, especially the SS, are very tightly wound cars. The transmissions, rear end/diff, suspension components, brakes are all tightly engineered. The prescribed break in procedures should be followed, then you can have a blast with it all you want.
Old 01-12-2016, 10:49 AM   #10
cartem2
cartem2's Avatar
Drives: Nightfall Gray 2LT RS
+1
It's funny how many people forget that they are breaking in an entire vehicle and not just the engine.
My Build Journal, Review, and Photos: Here
cartem2 is offline   Reply With Quote
Old 01-12-2016, 11:08 AM   #11
neal_zack
neal_zack's Avatar
look I get that this a breakin guide for a create engine. but step 9 on sheet 10 is where its goes a little left field.
Old 01-12-2016, 11:28 AM   #12
xgnxs
xgnxs's Avatar
You said it yourself. It's a break in guide for a crate engine. They're not giving you instructions on how to break in the vehicle you're putting the crate engine in, they're giving you instructions on how to break in the engine.
If you were building a vehicle and were putting in a new rear end, transmission, and crate engine, I guarantee you the break in guides for the rear end and transmission are not going to tell you to install them and then do a few WOT runs. They need to be broken in differently. My friend has one that needs to be broken in gently for 500 miles before any hard driving / quick acceleration / burn outs / etc.
You have to break in all of that stuff on the 6th gen.
Old 01-12-2016, 03:44 PM   #13
priusowners
priusowners's Avatar
Drives: 67LincolnConv 71Cuda 65CorvairConv
Attachment 766807
Sweet!
Try rhis link also:
http://www.sandyblogs.com/techlink/?s=no
C/D Yet?
priusowners is offline   Reply With Quote
Old 01-13-2016, 12:55 PM   #14
sdmcss
sdmcss's Avatar
Drives: 2018 Camaro 2SS 1LE, 1985 MCSS
You said it perfectly!
I remember back in 09' when people were receiving 5th Gens. People were doing quick mods on the first week. Then, they would go out and do a launch control take off. Then ask humm "How did I destroy my rear end? It's a new car!"
People, Murphy's Quantum Law: If it can go wrong. It will.
Just break in the car, the way it should be done.
sdmcss is offline   Reply With Quote
