Old 12-28-2015, 11:10 AM   #1
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
Has anyone confirmed if the manual LT1 Gen 6 has the AFM hardware or not?
Like the title says, does the LT1 have the AFM hardware in the engine or does GM just deactivate it in the software? Sorry if this has been covered.
Eric SS is offline   Reply With Quote
Old 12-28-2015, 11:18 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
There is no AFM on manual models.
Oh wait you asked about hardware. My "assumption" would be different hardware, but you know what happens when you "assume".
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 12-28-2015, 11:23 AM   #3
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I'm curious too. I had heard it would still retain the hardware but simply be deactivated. I wonder if any of this hardware can be removed to shave weight.
Old 12-28-2015, 11:48 AM   #4
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Pretty sure someone said that Al O. said the hardware is there, but it is off on the manuals...
Old 12-28-2015, 12:50 PM   #5
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
From what we were told, the AFM hardware is still in the manual versions, AFM is just disabled. Someone would have to tear a manual LT1 apart to say for sure, but I don't doubt that the parts are there.
xgnxs is offline   Reply With Quote
Old 12-28-2015, 12:53 PM   #6
mikeyg36
Drives: 2015 Z/28 #533
It seems pointless to spend the extra money on the AFM hardware and not activate it. I hope the shitty AFM lifters aren't in there.
mikeyg36 is offline   Reply With Quote
Old 12-28-2015, 01:08 PM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Thinking about it I bet they are (in there) as the engine is only listed as an LT1, whereas the 5th gen was LS3, L99.
FSP tuned: 377/389
Old 12-28-2015, 01:22 PM   #8
mikeyg36
That's what I was thinking. Plus the redline isn't increased.
Old 12-28-2015, 01:42 PM   #9
Bhobbs
Bhobbs's Avatar
They are. It's the same LT1 as the A8, but the AFM software is not active.
Old 12-28-2015, 01:43 PM   #10
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Correct, it's an LT1, made for AFM .....and start stop, coming sometime in the future, they say 2017 for the LT1 Vette.
Old 12-28-2015, 02:12 PM   #11
Eric SS
#becauseracecar
Eric SS's Avatar
OK thanks. That's a bummer. At least GM sells a non-AFM lifter/pushrod set if you want to change it out.
Old 12-28-2015, 06:48 PM   #12
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
You'd have to change the cam though too in order to switch to non-AFM lifters, right?
Old 12-28-2015, 06:52 PM   #13
mikeyg36
Not necessarily. You might as well though while you're in there.
Old 12-29-2015, 02:17 AM   #14
Brian 1LE SS
Drives: 98 Camaro SS
GM sells the heads minus the hardware in their performance catalogue.
98 Camaro SS M6, a few mods
13 Ram R/T, tow vehicle
6th gen??
<a href=http://www.norcal-lsx.com/multimedia/data/500/562752_4054654816027_115782456_n.jpg target=_blank>http://www.norcal-lsx.com/multimedia...15782456_n.jpg</a>
Brian 1LE SS is offline   Reply With Quote
