Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 12-24-2015, 11:37 AM   #1
NeedsWorkSS
NeedsWorkSS's Avatar
Drives: 2010 6.2L SS
Water sound rushing through behind the dash
Hey guys, i have a 2010 SS L99 with 40k on the odo. Recently i started hearing what sounded like water rushing through the dash and the smell of antifreeze. Yesterday my wife was driving it and she said the temp sky rocketted and the idle increased. She said she pulled over and the fan kicked on and cooled it off, she made it another 6 miles after letting it cool off and it did it again. I boughy this car from the dealer about 2000 miles ago. Do you guys think its a thermostat issue?, i intitally though heater core but theres no leaks under the dash.
NeedsWorkSS is offline   Reply With Quote
Old 12-24-2015, 12:32 PM   #2
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Leak somewhere dude. Check further.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 12-24-2015, 02:51 PM   #3
NeedsWorkSS
Ill just pressure test it
Old 01-01-2016, 07:59 AM   #4
weamonwe
Drives: camaro
weamonwe is offline   Reply With Quote
Old 01-01-2016, 10:53 AM   #5
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
You may be low on coolant. The heater core sits higher than motor so if it's low on coolant you'll get an air pocket in the heater core that'll make that noise. Best way to bleed system is on an incline so air can work its way out.
IMPERIALBLUE2SS is offline   Reply With Quote
