Old 12-18-2015, 09:30 AM   #1
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Two issues, one fixed.
The LED lighting in the cup holder didn't work. Dealership ordered a part, and it did not fix it. Pulled the console apart and found a connection not making connection. Repaired after 1.5 hours.
I turned on the option that points the side mirrors down when you reverse. Now, when I put the car back into drive, the driver's mirror goes past the saved position and points into the sky. Asking the dealer to look into this.
Old 12-18-2015, 09:52 AM   #2
jdasnt3
jdasnt3's Avatar
OK, dealer asked me to turn car mirror setting off, turn car off, and then mirror setting back on. It solved that issue, but now when I open the door with the car shut off, the driver's mirror points to the sky again. Interesting. Might need a re-flash.
Old 12-20-2015, 01:47 PM   #3
BlkReaper
Drives: 2016 2ss
If it changes positions only when you open the door, it is going to the easy out access setting. You can turn this off in the radio or you can set a different position. On the door where you have the set,1,2 buttons, the last button is the easy out access button. Set that where you want it to go
BlkReaper is offline   Reply With Quote
Old 12-20-2015, 04:47 PM   #4
jdasnt3
jdasnt3's Avatar
Originally Posted by BlkReaper View Post
If it changes positions only when you open the door, it is going to the easy out access setting. You can turn this off in the radio or you can set a different positing. On the door where you have the set,1,2 buttons, the last button is the easy out access button. Set that where you want it to go
Got it. Will check that. Thanks.
Old 12-20-2015, 05:47 PM   #5
jdasnt3
jdasnt3's Avatar
Big thanks to BlkReaper. My car is fixed. Now to tell my maintenance staff tomorrow so we don't have to take it in.
